1614 hydraulic valve
5 replies to this topic
#1 jjln50 OFFLINE
jjln50
  • 11 Thanks
  • 18 posts
Posted November 04, 2015 - 01:34 PM
  I would like to install a different hydraulic valve so I can use the 3 point hitch or the front blade independently. Any sugestions?
Thanks
#2 gopher OFFLINE
gopher
  • 763 Thanks
  • 757 posts
Posted November 04, 2015 - 06:08 PM
Case uses selector valve for that. You would use the same valve for both operations. Make sure you get the one for your system open or closed center.
  • jjln50 said thank you
#3 Dave Central NY OFFLINE
Dave Central NY
  • 106 Thanks
  • 92 posts
Posted November 04, 2015 - 06:38 PM
Check out  Surplus  Center
  http://www.surplusce...:0\ to\ 10\ GPM
I don't know how many GPM  the pump on a Power King puts out though.
#4 glgrumpy OFFLINE
  • 8,610 Thanks
  • 7,920 posts
Posted November 04, 2015 - 06:59 PM
You will need much more. the "Rockshaft" under the tractor has the arms for lifting or pushing the attachments. There is Only one on tractor now and one cylinder. that is why when one in front goes up, the back goes down and etc. You would need seperate cylinder or rockshaft also for that type system.  If you have room, suppose one could take a stock lift and make new mounts on frame somewhere that wouldn't be in way, but not sure. OR, could have a front blade cylinder and mount in front vertically maybe to lift the blade there, using stock mounts for the blade still. Later years plastic kings had double valve option, buy at moment I"m not sure where or how that was installed. But those are a different animal than metal ones.
  • Alc and jjln50 have said thanks
#5 jjln50 OFFLINE
jjln50
  • 11 Thanks
  • 18 posts
Posted November 04, 2015 - 07:06 PM
Well it was a good idea. Thanks
#6 countryboy88 OFFLINE
countryboy88
  • 102 Thanks
  • 144 posts
Posted November 24, 2015 - 08:41 PM
I added hydraulics for my 3 pt and left the manual lift in the front, I did this so I could lift more weight.
I removed the connecting bar that went from the bar with the hole hanging down in the first pic to the bar the cylinder is connected to in the second. FYI I did this to my Jim Dandy, a Power King will be different.
