Easy Way to stop Windows 10
10 replies to this topic
#1 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted November 03, 2015 - 09:55 AM
http://www.pcworld.c...10-upgrade.html
  • OldBuzzard, Bruce Dorsi, Cvans and 1 other said thanks
#2 HDWildBill OFFLINE
  • 8,978 Thanks
Posted November 03, 2015 - 02:01 PM
Easy fix to Window 10 issue.  Install Linux and let it wipe your drive and repartition and format it.  Problem fixed.  :D  :thumbs:
  • Trav1s said thank you
#3 chieffan OFFLINE
  • 10,962 Thanks
  • 6,946 posts
Posted December 01, 2015 - 08:44 AM
But what if I don't want to take the time to learn a completely new operating system?  I am not that computer save to start with so the easier it is the better for me.  I have never knew anything but windows.
#4 MH81 OFFLINE
Posted December 01, 2015 - 10:08 AM
A couple of the linux versions are imitations of XP. There is a learning curve, but not bad.
Bill is your best bet, but I've dabbled a couple times and been surprised how good it is.
There are two programs I have to run for work that ONLY will work on a windows PC.
#5 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted December 01, 2015 - 10:21 AM
https://www.yahoo.co...-132034750.html
#6 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted December 01, 2015 - 10:23 AM
linux Mint is an easy transition if you want to explore it.  Download the image, create a bootable USB drive, and boot to the USB drive and play around with the live version.
#7 HDWildBill OFFLINE
  • 8,978 Thanks
Posted December 01, 2015 - 11:14 AM
Have you conidered maybe running window in virtual mode or see if your programs will run under wine?
#8 HDWildBill OFFLINE
  • 8,978 Thanks
Posted December 01, 2015 - 11:24 AM
There are quite a few distrubutions that follow the windows design and make it easier to transition over.  Like Travis said there is Mint but there is also Zorn that has the ability to XP or Windows 7 or  Linux, LXLE, Mageia.  The nice thing, I think, about Linux is that most of the distrubutions all have forums with folks that actually use that distro and are knowledgable to help you.  Chieftan the main thing you would need to do is let them know up front that you are not computer savy.
#9 MH81 OFFLINE
Posted December 01, 2015 - 04:50 PM
Bill, have you tried PCLinuxOS?
#10 HDWildBill OFFLINE
  • 8,978 Thanks
Posted December 01, 2015 - 06:07 PM
I'm using it right now and have been using it for over a year.  I have it installed on this computer, shop computer and laptop.
#11 Cvans ONLINE
  • 7,154 Thanks
  • 6,313 posts
Posted December 03, 2015 - 03:23 PM
Installed the above mentioned software and it works perfect. Thanks for bringing it to our attention.  :D
