Cub cadet k301 crank question
3 replies to this topic
#1 welderman85 OFFLINE
welderman85
  • 38 Thanks
  • 53 posts
Posted November 02, 2015 - 07:42 PM
Hello all I just was wondering if a k301a and a 301aqs use the same crank one has a big stater/gen and the the other just has the small starte. Thank you
  • Retired Signaller and augustn1 have said thanks
#2 KennyP ONLINE
  • 40,886 Thanks
  • 47,094 posts
Posted November 02, 2015 - 08:06 PM
:wave: Welcome to the forum! Do you by chance have the spec #'s for these engines?
#3 welderman85 OFFLINE
welderman85
  • 38 Thanks
  • 53 posts
Posted November 03, 2015 - 06:29 AM
Thank you yes one is 47138b and the other is 47622d
#4 KennyP ONLINE
  • 40,886 Thanks
  • 47,094 posts
Posted November 03, 2015 - 07:21 AM
Great. Now we check the parts manual to see if they will interchange. According to that manual, they use the same crank. But on serials before 153010013, crankshaft 47 014 05# was used. After Serial 153010003, crankshaft 47 142 30* was used.
For the # & * notes we have this:
Then I went to the Kohler Crankshaft Reference PDF and found this:
I would say they will interchange from this info.
