John Deere LX178 no start
3 replies to this topic
#1 Knimi OFFLINE
Knimi
  • 2 posts
Posted November 02, 2015 - 07:36 PM
I have a 1994 John Deere LX178, serial #MOL178A070022 with Kawasaki FD440V 15hp liquid cooled engine. It has an intermittent starting problem. Sometimes it starts and runs normal. Other times (like today) it will not start. Does not turn over, no dash lights come on, no starter click, it's completely dead. If I leave ignition on, and jumper from starter 12v power to solenoid terminal, engine turns over and started once for a few seconds (sounded real weak, maybe running on one cyl?). Battery voltage is at 12.5v. I checked for power at the 2 small coil terminals, they were both less than 5 volts. Any ideas where to begin diagnosing this? I really don't want to start throwing parts at it, they are not cheap.
Thank you
#2 Eric OFFLINE
Eric
  • 1,322 Thanks
  • 813 posts
Posted November 02, 2015 - 07:57 PM
I am not familiar with your specific mower but it sounds like you may have a short somewhere. You should run your wiring down connection to connection and look for frayed or burnt wiring before replacing anything, you can also start checking continuity. Have you by chance tried checking your ignition switch? Someone who may be familiar with your equipment should be along shortly!
#3 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,748 Thanks
  • 4,242 posts
Posted November 03, 2015 - 04:37 AM
Welcome to GTt. Here some answers, you can find at JD groundscare:
Attached File  237.pdf   44.06KB   101 downloads  Attached File  240.pdf   5.6KB   85 downloads  Attached File  241.pdf   5.86KB   78 downloads
#4 Knimi OFFLINE
Knimi
  • 2 posts
Posted November 04, 2015 - 01:14 PM
Thank you for the replies. The ignition switch is a fairly complicated looking unit, has a circuit board attached. Not sure how to test it. Any advice on testing the ignition switch?
Thank you
