JD 140 belt length ?
8 replies to this topic
#1 propane1 ONLINE
propane1
  • 9,444 Thanks
  • 4,386 posts
Posted November 01, 2015 - 06:06 PM
Wondering the length of belt between the JD 140 engine to the snowthrower ? And is it a model 49 thrower that fits the 140 ? Thanks for any help. Noel
#2 hdg4400 OFFLINE
hdg4400
  • 294 Thanks
  • 357 posts
Posted November 01, 2015 - 06:34 PM
propane1:
That picture looks like the tractor/blower setup that I had for probably 20 years, and I was lucky enough to have a cab for my 140. Yes, it is the 49 snowblower  that fits the 140, and I still have the Operator's Manual (paper and PDF) for it.
I don't know the length of the belt, but the part number and belt specifications should be available at jdparts.com. Most people say you should use JD belts (at least for mowers) because the V groove angle is different than other V-belts.
Also, the OM shows different installation instructions for early and later 140's which might mean the belt may be different lengths.
Harlan
  • propane1 said thank you
#3 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted November 01, 2015 - 07:20 PM
The part number for the belt is M42485
  • Bolens 1000, Trav1s and propane1 have said thanks
#4 propane1 ONLINE
propane1
  • 9,444 Thanks
  • 4,386 posts
Posted November 01, 2015 - 07:40 PM
I was wondering the length of the belt. I am going to look at a thrower this week end. And hope to hook it the the tractor to see if it works on my tractor. It is on a JD 317 now. I don't know if the belt is the same for both tractors. So I was going to take a belt with me if the one he has or doesn't have won't fit my tractor. I have some belts here , so I don't want to buy one just yet, until I know the thrower will fit and work. Noel
Thanks for the part number.
#5 Trav1s ONLINE
Trav1s
  • 3,577 Thanks
  • 4,550 posts
Posted November 01, 2015 - 08:06 PM
A blower from a 317 will without question work on your 140.  The later model 49 that I have came from someone who used it on a 318.  I bolted it on my 120 with the correct belt.  From what I remember, any Kohler single powered tractor (120/140/300/312/314/316k) use the same belt that Troy posted.
  • johndeereelfman and propane1 have said thanks
#6 GWest OFFLINE
GWest
  • 555 Thanks
  • 507 posts
Posted November 02, 2015 - 04:55 AM
Gates makes a 6846 to replace the M42485. Should also be available from Napa as 4L460W
1/2" x 46" outside circumference
Garry
Edited by GWest, November 02, 2015 - 04:59 AM.
#7 Trav1s ONLINE
Trav1s
  • 3,577 Thanks
  • 4,550 posts
Posted November 02, 2015 - 09:04 AM
Here is the new blower on my 120 before it got prettied up.  I had to do new hoses for the cylinder and the local napa helped with that.
#8 propane1 ONLINE
propane1
  • 9,444 Thanks
  • 4,386 posts
Posted November 02, 2015 - 09:39 AM
Thanks Trav1s for the pictures. That will help with installing the chute turning handle.. Noel
  • Trav1s said thank you
#9 Trav1s ONLINE
Trav1s
  • 3,577 Thanks
  • 4,550 posts
Posted November 02, 2015 - 10:27 AM
That bracket on the handle is for the later style mount on the 318 so I used large rubber isolators from automotive shock absorbers along with carriage bolts to attach the handle to the pedestal.
