New to this site and a new tractor. Lots of questions
17 replies to this topic
#16 MNGB ONLINE
MNGB
  • 2,627 Thanks
  • 1,570 posts
Posted November 09, 2015 - 01:13 PM
Hi the B&S 32xxx series has the right bolt pattern but B&S crankshafts are 1" vs 1.125 for the Kohler's, so if you found a B&S you would need a CS sleeve adapter they are about $20.00, I would thing with some looking you could find a Kohler to use or rebuild, I found 3 here in MN when I needed one for the PK just don't get one from a John Deere completely wrong, one from a Case will have a short crank PTO so that CS will not work but the block would be ok, there are a number of block listed on e bay.
#17 RBOWKER OFFLINE
RBOWKER
  • 8 Thanks
  • 6 posts
Posted November 09, 2015 - 01:36 PM
Running power kings this size in this area seem to be 600 to 1200.
K series short blocks is 1200 and mini block is 900.
I think I'm going to put a kohler CH25 in it. My friend is a Walker dealer an has tons of stuff.
. The bell lines up perfect to the block, so I'm going to do a dry fit with an empty block this afternoon
#18 MNGB ONLINE
MNGB
  • 2,627 Thanks
  • 1,570 posts
Posted November 09, 2015 - 01:47 PM
Yea that should work if you look a couple of threads down there is a fellow meber that has a twin V Kohler in his PK.
