Allis Chalmers B110's equivalent in Simplicity
4 replies to this topic
#1 TimW OFFLINE
TimW
  • 414 Thanks
  • 271 posts
Posted October 31, 2015 - 09:11 PM
I am a bit confused on exactly, or close Simplicity that is the twin, if there is one, of the Allis B110.  Also, I picked up several accessories that are all Allis.  Are the decks, front blades, sickle bars the same as Simplicity models?  I know the sheet metal may be a bit different, but is there a mechanical equal?  I will try to get some pics of this package I picked up.  It has a fairly nice original B110, dual wheel option, headlights, deck, front blade, Allis wagon, and the jewel, sickle bar mower.  I have worked on several Simplicitiys, but not one of the '67-'70 era.
Thanks
Tim
  • MNGB said thank you
#2 Dee OFFLINE
Dee
  • 55 Thanks
  • 69 posts
Posted October 31, 2015 - 09:34 PM
http://www.simpletra...ce/ac_s_pg1.htm
  • TimW said thank you
#3 TimW OFFLINE
TimW
  • 414 Thanks
  • 271 posts
Posted October 31, 2015 - 09:38 PM
I looked all over that sight and could not find that chart.  Thanks.
#4 boyscout862 ONLINE
  • 12,552 Thanks
  • 9,044 posts
Posted October 31, 2015 - 11:47 PM
Take a look at this manual: http://gardentractor...ers-parts-list/ . The B110 and the 2110 are probably the equivalents. None seem to be exact. Good Luck, Rick
Edited by boyscout862, November 01, 2015 - 12:03 AM.
#5 Talntedmrgreen OFFLINE
  • 3,230 Thanks
  • 2,301 posts
Posted November 01, 2015 - 06:49 AM
Yes the 2110 is identical to the b1 10 with the exception of the hood steering wheel seat and grill. Of course the different colors with different decals.
There are two varieties of the b110... an early and a late. The early tractors have a push button start in the late type has a key start with safety switch starter solenoid.
All simplicity attachments will fit the Allis and vice versa. they will work on tractors 1970 and older. Some attachments work on later tractors but there were generally variations in the Hitches due to some of the changes to the frame on later model tractors.
  • boyscout862, TimW, TomLGT195 and 1 other said thanks
