PK 1618 Front Spindle thrust bearing P/N ?
4 replies to this topic
#1 MNGB ONLINE
MNGB
  • 2,138 Thanks
  • 1,416 posts
Posted October 31, 2015 - 01:17 PM
Hi all, this winter I'm going to replace the worn spindle bushing with new, (I have the bushings) been thinking that replacing the spindle thrust bearings might also be a good idea, I've searched some but haven't found a generic bearing number for the PK numbers Old number is B24 newer number is 80-0024 anyone have a number that I can go to the local bearing store and get a couple?
#2 pharmer OFFLINE
pharmer
  • 871 Thanks
  • 774 posts
Posted October 31, 2015 - 02:03 PM
Look at McMaster Carr website. They have them. Maybe a local store can cross them for you.
#3 glgrumpy OFFLINE
  • 8,617 Thanks
  • 7,923 posts
Posted October 31, 2015 - 06:16 PM
I see you on other forum, but have maybe found a number.  This is hand written note I had in stuff.
Timken T 113
Hub seals National 205005
Wheel bearings NSK LM11949
Also found McMaster-Carr receipt
Steel ball thrust bearing for 1-1/4" shaft, diam 2-11/32 OD, Sheilded     60715k27 there number $20.53, but old price from 2008.
Aloy Bronze sleeve for  1" shaft, 1-1/8" od, 4" length 6381K18   Must have cut them then? Don't recall.
  • MNGB said thank you
#4 MNGB ONLINE
MNGB
  • 2,138 Thanks
  • 1,416 posts
Posted October 31, 2015 - 06:38 PM
Hi GL thanks that's what I was wanting to learn, I'll give those numbers a try.
I was looking at some photos of your TC / MM nice looking tractor and the BG is also nice.
Thanks again
#5 glgrumpy OFFLINE
  • 8,617 Thanks
  • 7,923 posts
Posted October 31, 2015 - 07:35 PM
I've sold MMs, but now have R to work on, will be awhile for it. Still have yellow, or gold Gts though.
