DB walk behind joins the family
56 replies to this topic
#46 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted January 24, 2016 - 11:38 AM
we used to get those grips from some Gravely dealer out in WV yrs back, might be the same place.  Exhaust that been run any length of time will almost weld itself together. you could try some heat and see where that goes, or just cut it off and split the threads with a hack saw blade.
#47 Pats OFFLINE
Pats
  • 20 Thanks
  • 27 posts
Posted January 24, 2016 - 09:28 PM
Full disclosure, I'm brand new to the DB and know next to nothing but just dealt with replacing an old exhaust pipe. Soaked the threads for a couple days with penetrating oil, then applied a 24" pipe wrench and slowly twisted and prayed. Luckily the wrench found a good purchase and the pipe came loose. Good luck.
  • drknobhead said thank you
#48 drknobhead OFFLINE
drknobhead
  • 2 Thanks
  • 4 posts
Posted January 25, 2016 - 08:07 PM
any ideas on how to make the gas stop spewing out the weap hole at the bottom of my carb?  Take my carb apart and unstick my float?
#49 drknobhead OFFLINE
drknobhead
  • 2 Thanks
  • 4 posts
Posted January 26, 2016 - 09:26 PM
Hey it worked! Thanks man!
  • Pats said thank you
#50 Sugarmaker OFFLINE
Sugarmaker
  • 239 Thanks
  • 181 posts
Posted January 27, 2016 - 03:44 PM
Ok, I actually found the receipt tonight for the used Black Grips for the David Bradley.  I was wrong about Tennessee, it was in WV.  Richard's Lawn & Garden Equipment, phone number is 800-827-4551 or 304 927 4580, and with shipping, they came to $5.30 a piece.
Besides my carb leaking, I also have a straight pipe that my grandpa put in for the exhaust back in the 50's.  Any idea how to get it unscrewed to put my Model N muffler threaded in? Vice grips and pipe wrench not getting it to turn.
My carb did exactly the same thing first time I put gas in the tank. Leaked from that small drain hole. I took the carb apart several times. Bought a rebuild kit and some spare parts. Adjusted the float to have less gas in the bowl. Works as it should now.
Thanks for the info on the repro grips. These from McMaster-Carr Are OK but not quite like the original ones. I may check with Richards in WV to see if he has any more grips.
Ok just got off the phone with them and I have a pair on the way. They said they matched the originals.
Regards,
 Chris
#51 Sugarmaker OFFLINE
Sugarmaker
  • 239 Thanks
  • 181 posts
Posted January 27, 2016 - 03:48 PM
Ok I may have missed something here. Your avitar shows a completed DB painted up. So I assume that its done and just leaks gas? If that's the case then changing the float level may help a lot.
Regards,
 Chris
#52 Sugarmaker OFFLINE
Sugarmaker
  • 239 Thanks
  • 181 posts
Posted March 31, 2016 - 01:30 PM
Folks,
I did get he DB out for a spin. Added gas and the Model N engine fired up on the second pull.
 drove it around for a bit then installed the hand grips. First one did not get quit all the way on. The best way to install would have been to plug the end of the metal handle bar wit the cork then inflate the grip as it went on. Well I was smarter on the second one and used blak electical tape to seal the end of the handle bar. Also added a little dish soap on the inside of the grip. inflated and it went on pretty easy.
When I was ready to put it away it started to smoke. Not sure what that is about need to check the oil prior to next outing.
Regards,
Chris.
Edited by Sugarmaker, March 31, 2016 - 01:31 PM.
#53 Sugarmaker OFFLINE
Sugarmaker
  • 239 Thanks
  • 181 posts
Posted July 24, 2016 - 10:08 PM
Folks,
 Been a while!
I still have the family David Bradley! I cultivated the sweet corn with it when it was 10 inches tall.
I took the DB to its first show. Along with 5 other tractors. I think the old DB got more attention than any of the others. It started right up and just purred at low idle. Local DB guru brought me a new gear drive and dogs and springs for the right wheel which is not driving. Thanks Darrell!
Regards,
 Chris
#54 Sugarmaker OFFLINE
Sugarmaker
  • 239 Thanks
  • 181 posts
Posted July 28, 2016 - 07:44 AM
Folks,
 I changed out the drum on the right side of the drive axle. The old drum with the teeth were very worn on the points.The new drum had sharp points and it worked very well. Much better when both wheels are driving!
This is a nice little garden tractor, I have had a lot of fun with. That old N series Briggs sure sounds nice! Thanks for the support on this project!
Regards,
 Chris
#55 Sugarmaker OFFLINE
Sugarmaker
  • 239 Thanks
  • 181 posts
Posted September 25, 2016 - 07:11 AM
Pleased to report the old DB is running good for a 60+ year old machine! Have taken it to several shows and it starts right up and purrs at a idle! Folks seem to like the bullet nose design! Thanks for the support getting this family tractor going!
Replacing that bad hub made the tractor pull with both wheels and work as it should. Thanks to Darrell in NW PA For the hub!
 Regards,
 Chris
  • Alc and MGP59DB have said thanks
#56 Sugarmaker OFFLINE
Sugarmaker
  • 239 Thanks
  • 181 posts
Posted April 26, 2017 - 07:22 PM
Folks,
Taking a break tonight from a non tractor project! Thought I better check in! Spring has sprung big time in our next of the woods!
Our Great Grandson Rhett comes over two days a week. Cheryl watches him, I just try to keep up with him:)
This past Monday he was checking out all Papa's tractors! Which can take a while as he wants to ride each one. He is 2 years old on the 28th of April.
Last but not least, he came to the David Bradley. He said in his best German or Swedish accent, "Papa rope, get rope for putt- putt"! I grabbed the starter cord hanging on the cross bar, turned on the gas, Lifted and set the hood, set the choke, wrapped the rope on the starter pulley, gave it a yank and his, great, great, great, great grand fathers, David Bradley, fired right up at a slow loping idle, a sweet sound that only a little N can make. (A sound that kids seem to love!) Rhett's blue eyes just danced with excitement as we crouched down next to the big wheel, and we listened to the old girl "PUTT-PUTT" along for a few minutes as I adjusted the choke!
Priceless moment we shared! Glad I brought this machine home and got it operational. instead of letting it go to the scrappers!!!!
I told Cheryl when I go to the big garden in the sky, this old PUTT-PUTT goes to Rhett!
Regards,
 Chris
  • Alc, Zekkjacen and MGP59DB have said thanks
#57 MGP59DB ONLINE
MGP59DB
  • 1,718 Thanks
  • 786 posts
Posted May 01, 2017 - 11:16 AM
Glad to hear that !Great little story .  I 've been looking around for the right one of these to get.
Edited by MGP59DB, May 01, 2017 - 11:17 AM.
