Motor For 1476
24 replies to this topic
#16 Bigdaddydon OFFLINE
Bigdaddydon
  • 121 Thanks
  • 253 posts
Posted October 31, 2015 - 10:29 AM
The stator from the Tra12D is NOT interchangeable with the 14 horse.
Have you had the flywheel off?  You can easily tell if the stator is original or "overnight solution".
Also you can check to see if the wire from the stator has rubbed on the flywheel and is grounding out.  This can and has happened, I know.
Judging by the length of the mystery white wire I would say it went to the back of the dash and connected to the secondary switch.
  • chieffan said thank you
#17 chieffan ONLINE
  • 16599 Thanks
  • 9089 posts
Posted November 01, 2015 - 08:17 AM
Thanks to one of our members I purchased a NOS stator and electronic ignition module off eBay.  Should be here by Friday and if my coil is good ? I may get an engine running next weekend.  Mean time I better work my butt off and get some firewood cut for winter.  Have had some knee problems with Uncle Arthur paying a visit and not wanting to leave.  Going to rest it today and then go after the wood.
Edited by chieffan, November 01, 2015 - 08:18 AM.
  • Bolens 1000 and accidentalchild have said thanks
#18 accidentalchild OFFLINE
accidentalchild
  • 382 Thanks
  • 463 posts
Posted November 23, 2015 - 11:44 PM
any news? is it running yet?
#19 chieffan ONLINE
  • 16599 Thanks
  • 9089 posts
Posted November 24, 2015 - 06:13 PM
Had the flywheel looked at today by a twin and v4 Wisconsin mechanic.  could see nothing wrong with it.  Magnets are good. Back together part way tomorrow and see if I can get spark.  Everything is new from the coils to the spark plug.
#20 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5122 Thanks
  • 2911 posts
Posted November 24, 2015 - 06:46 PM
"NEW" does not always = "GOOD"
#21 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted November 24, 2015 - 06:49 PM
Did the guy have any suggestions for you or has run into a problem like this before?
#22 chieffan ONLINE
  • 16599 Thanks
  • 9089 posts
Posted November 26, 2015 - 03:39 PM
That is true.  Coil has been switched between the new one and original.  No change.  Guess I could swap the module first as that is the easiest to get to.  If that don't do it, could put the old stator in with the new module and new coil.  Real PITA to change that stator again.  Changing is easy, getting to it is whats tough.
Edited by chieffan, November 26, 2015 - 06:18 PM.
#23 chieffan ONLINE
  • 16599 Thanks
  • 9089 posts
Posted November 26, 2015 - 03:41 PM
They have not worked with any of the Wisconsin's with electronic ignition.  Most of the skid steers, etc. they work on are the older ones.  This guys has been working on this kind of stuff for a lot of years as he is in his 70's.
#24 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3494 Thanks
  • 3384 posts
Posted November 26, 2015 - 03:59 PM
I have a 1455 with the s14d with no spark as well. I remember reading in a thread somewhere that said there were issues with the ignition switch and another electrical part that would cause a lot of problems. Is your switch good? Will see if I can find that thread - it was in another forum.
#25 chieffan ONLINE
  • 16599 Thanks
  • 9089 posts
Posted November 26, 2015 - 06:25 PM
Not using the ignition switch.  I added a push button switch for a kill switch and that is all.  No connection between the 12V system and the ignition system.  I think the issue your referring to is the possibility of 12 V feeding back into the ignition system from the regular key switch.  If it does, it blows the module and possibly the stator.  That has not occurred to mine as there was no ignition switch when I got the tractor.  Everything has been installed new.  But like Bruce Dorsi said NEW does not mean GOOD.  Keep me posted if you ever get your going and I will do the same.
  • sacsr said thank you
