A Childhood Dream Realized...My Very Own T70ES
panzer t70
428 replies to this topic
#376 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted March 26, 2016 - 12:54 PM
If you give me the model numbers of the motor an the hp I can check my Napa small engine parts book to see if there available some wheres
  • Chris11 said thank you
#377 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Maybe I got the last of them. Lol I have the valve cover gaskets at home.
  • backwoods said thank you
#378 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted March 26, 2016 - 01:06 PM
heres my tag
#379 Hondarider OFFLINE
Hondarider
  • 402 Thanks
  • 273 posts
Posted March 26, 2016 - 07:21 PM
All this talk about the engine got me thinking...
When I tore down the tractor, the engine was the last thing that I removed after everything else was stripped. Now I've reassembled almost everything and the engine is still sitting on a bench. I'm usually very disciplined about following the disassembly process in reverse when putting something back together.
Today, I decided that I should see if I'll be able to reinstall the engine at a later date if I continue on my current path of reassembly.
I didn't install the motor plate, but I still had adequate space to get it in without any assistance. If I had removed the spark plug or the starter, I think it would have slid right in there.
#380 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted March 26, 2016 - 08:30 PM
For the lateral slop, I found a couple .375" spacers that fit very well.
I polished up the shaft, chamfered the ends with a file, and put it all together.
Muy bueno!
Are you planning on putting a deck under it? If so does the horizontal slop need to be there to get the deck hooked up?
I'm sure you checked that as detail oriented as you are. Beyond impressed with your work!
  • Hondarider said thank you
#381 jabelman OFFLINE
jabelman
  • 2,238 Thanks
  • 1,600 posts
Posted March 26, 2016 - 08:48 PM
I have done over a few 143302's it's no hassle finding nos parts they are out there
#382 Hondarider OFFLINE
Hondarider
  • 402 Thanks
  • 273 posts
Posted March 26, 2016 - 09:00 PM
I am planning to run a deck under it and you might be correct. The deck hangs from a couple chains so I suspect there's already some allowance for side to side motion in there, but I have to admit that I didn't really scrutinize it too closely during disassembly. If it does turn out to be too tight a fit, I suppose I can remove the plastic spacers pretty easily. I installed hitch pin clips all over the place so it should disassemble in minutes if I need to fine tune my ideas.
  • 1964Deere said thank you
#383 jabelman OFFLINE
jabelman
  • 2,238 Thanks
  • 1,600 posts
Posted March 26, 2016 - 09:10 PM
your machine is too nice to run deck! your doing one heck of job on it. I see your other hobbies with the bikes, cars etc. I did the same, I still have one of my mustangs and being 100% honest these panzers and other garden tractors I have more fun with restoring and cruising around with the kids.
Edited by jabelman, March 26, 2016 - 09:11 PM.
#384 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 4,103 Thanks
  • 1,897 posts
Posted March 27, 2016 - 07:49 AM
I had no problem finding valves, piston, rod, rings, points, etc. for my engine.
The only thing I had a problem with was that complete gasket set with the oil seals.
Edited by jdcrawler, March 27, 2016 - 07:50 AM.
#385 Hondarider OFFLINE
Hondarider
  • 402 Thanks
  • 273 posts
Posted March 27, 2016 - 09:56 AM
HAPPY EASTER!!
Family dinner at 1:00 today. Am I the only guy who cleans his garage whenever company is coming? I hate the idea of people seeing a messy shop.
  • Alc, KennyP, Clint and 1 other said thanks
#386 shorty ONLINE
shorty
  • 5,774 Thanks
  • 5,390 posts
Posted March 27, 2016 - 03:31 PM
HAPPY EASTER!!
I close n lock the door...
In other words, I don't like cleaning.
#387 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted March 27, 2016 - 03:37 PM
They learn to deal with the mess or they stay out!
#388 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted March 27, 2016 - 04:43 PM
HAPPY EASTER!!
HAPPY EASTER!!
Ya I clean up the chips so it looks like I don't do anything
#389 Hondarider OFFLINE
Hondarider
  • 402 Thanks
  • 273 posts
Posted March 27, 2016 - 06:43 PM
WTF? Are you an actual machinist? You should be giving me all sorts of tips and information. I'm over here winging it like a chimp and you know how to actually make chips. I'm not sure what that is a picture of, but it sure puts all of my crappy brackets to shame.
#390 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted March 27, 2016 - 06:47 PM
go in the puller forum and look at LETS CALL IT DB2
Also tagged with one or more of these keywords: panzer, t70
