You can't beat 50 rounds. I think my Crossman 760 holds like 200. The pumping gets old after a while.
A Childhood Dream Realized...My Very Own T70ES
#286
OFFLINE
Posted February 22, 2016 - 09:02 PM
- Alc said thank you
#287
OFFLINE
Posted February 28, 2016 - 06:59 PM
Knowing that I need to do a bit of fabrication to correct a couple things that I don't like about the original design, I've been scouring Craigslist for about a week in search of a belt sander. Now that I've got the lathe and the milling machine squared away, I'd really like to find a sander to round out the shop. What I'd really like is a Delta-Rockwell like the one I had in my old shop.
I could have taken it with me when we closed the doors, but it was 550VAC/3 phase and I didn't have a lot of storage space at my house. Had I known how hard it would be to find another one of that quality, I would have replaced the motor and found a place to store it. In a moment of abject ignorance, I let it go to the scrap yard.
Sadly, my search only uncovered one unit...2.5 hours away from my house...and it was gone before I could even hit the road with a pocket full of cash.
Instead, I cobbed something up in my backyard...
#288
OFFLINE
Posted February 28, 2016 - 07:15 PM
As I assembled the tail end of the Panzer, I wasn't happy with the relationship between the sheet metal chain cover, the battery tray, the seat leaf spring, and the tool box. There's a lot of rubbing and bending and scratching and pinching. Now that may sound like a rockin' good Saturday night with Amber Heard, but it's no way for freshly painted parts to interact with one another.
I've spent the requisite couple weeks staring at the problem...I've picked up some flat steel bar in various widths and thicknesses...and today I was ready to get after it. I'm a little ashamed to say that I spent most of the day cutting, welding, and grinding...just to end up with this little paper weight...
Edited by Hondarider, February 28, 2016 - 07:18 PM.
#289
OFFLINE
Posted February 28, 2016 - 07:29 PM
I still have to drill some holes in it and paint it, but the mock-up seems to address my concerns. The rear edge of the sprocket cover rests at just the right height to provide clearance for the left implement lever and the battery plate sits just above it...not making contact at all...though I may add a piece of plastic edge protector to the front edge of the battery plate just for safe measure.
The additional altitude also means that the leaf spring will no longer rub on the cover.
Edited by Hondarider, February 28, 2016 - 07:32 PM.
#290
OFFLINE
#291
OFFLINE
#292
OFFLINE
#293
OFFLINE
Posted February 28, 2016 - 08:18 PM
It's really hard to describe that as 'beefy' and 'simple' when it looks so darn nice.
#294
OFFLINE
Posted February 28, 2016 - 11:54 PM
#295
OFFLINE
Posted March 05, 2016 - 03:26 AM
Another 50+ degree February day in New England. It doesn't make any sense, but I'll take advantage of the opportunity for some spray painting. The collars for aligning the right lever to ensure positive engagement of forward and reverse.
If anyone has a rusted or bent shaft or their collars are broken or stripped from overtightening, these seem to work quite well. No disassembly required on the shift lever arm!
Copy and paste this into ebay.
3/4 SINGLE SPLIT SHAFT COLLAR BLACK OXIDE 3/4" 1 PIECE CLAMP COLLAR-USBB
#296
ONLINE
Posted March 05, 2016 - 05:42 AM
Ace hardware carries those here!
- Alc and Clint have said thanks
#297
OFFLINE
Posted March 05, 2016 - 11:23 AM
I apologize for the delay in Panzer progress, but I have been temporarily sidetracked by my daughter's science fair project. I think I probably enjoy these more than she does (I hope I get an A). She's doing the work...I'm just providing the hardware. Any guesses on what scientific principle she's going to demonstrate?
#298
OFFLINE
Posted March 09, 2016 - 08:51 AM
Block and tackle?
#299
OFFLINE
#300
OFFLINE
Posted March 11, 2016 - 01:01 PM
When I last checked in, I had fabricated a spacer and I was pondering how I might integrate it into the Panzer. At first, I thought that all I needed were 2 simple holes spaced 2" apart. Then after some long deliberation and test fitting, I decided I would need 4 threaded holes instead; altering the original design of the tractor just a bit.
I probably spent 3 days just mocking up parts and wondering if my alteration might have some undesired consequence elsewhere...reducing spring tension on the implement arm...causing interference between painted parts...lifting the hood to some strange angle. In the end, I was fairly confident that my small change would only pay positive dividends and no ill effects. I was committed to making holes.
