Vote for Tractor of the Month
For Sale
Case / Ingersoll three point arms
12 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,496 Thanks
  • 7,345 posts
Posted October 29, 2015 - 12:29 AM
I have a pair of lower lift arms, side lift links, and adjustable top link original to a Case / Ingersoll three point setup. If anyone needs these I am holding them ransom for a pair of lower lift arms better suited to my New Holland S-14 that will help me line up with the rockshaft lift arms when making my side lift links. Open to most offers, including CASH, but prefer lower lift arms similar to what I have, but better fitting to my tractor. Thanks.
#2 glgrumpy OFFLINE
  • 6,827 Thanks
  • 6,621 posts
Posted October 29, 2015 - 07:11 AM
Ummmm! Want straight, dog leg, real heavy or regular?  Thickness and width of metals then is meant here?? Swivel balls both ends?  What the Case ones look like?  I have made my own lower links by buying heavy bar stock and the O cat balls from Farm catalogs and shaped the end of stock to fit around the balls outers a bit and had them welded on, just like a boughten set. I copied some from Power King. They looked good and worked well. You can also get the ends with a little bit of straight metal on them to weld to if you prefer, but not sure if cat O in those, might be Cat 1 size. Think Steiners is where I got them.
  • Delmar said thank you
#3 wvbuzzmaster OFFLINE
  • 4,496 Thanks
  • 7,345 posts
Posted October 29, 2015 - 07:20 AM
The case ones dog leg over for around tires and are around 20" long. I hate to exceed 20" long, but still need them to dog leg, just not all at once like the Case arms. I dont want straight either, so a bend at each end, a ball on each end, and holes in the middle.
  • shorty said thank you
#4 KennyP ONLINE
  • 29,571 Thanks
  • 40,547 posts
Posted October 29, 2015 - 07:31 AM
Can we see some pics of what you have? If I had some idea of what the NH arms should look like, I might be able to help you out. How far from the attaching point of them ton the tires? How far apart are the attaching points?
  • wvbuzzmaster said thank you
#5 wvbuzzmaster OFFLINE
  • 4,496 Thanks
  • 7,345 posts
Posted October 29, 2015 - 08:58 AM
Only picture i have since i changed phones this week.
#6 wvbuzzmaster OFFLINE
  • 4,496 Thanks
  • 7,345 posts
Posted October 29, 2015 - 09:02 AM
Gas tank is not installed and sticks past the frame on both sides. Only about 3/4" space between gas tank and rockshaft arms. This makes my side links a challenge some.
#7 shorty ONLINE
shorty
  • 3,917 Thanks
  • 4,223 posts
Posted October 29, 2015 - 09:53 AM
I think original would be straight arms with the heim joint on an slight angle. About 16" long.
#8 shorty ONLINE
shorty
  • 3,917 Thanks
  • 4,223 posts
Posted October 29, 2015 - 09:10 PM
This is what I have from the Ariens.
#9 wvbuzzmaster OFFLINE
  • 4,496 Thanks
  • 7,345 posts
Posted October 29, 2015 - 09:48 PM
I like those Eric, they will hook right to the lift rockshaft also. What are you doing with them?
#10 shorty ONLINE
shorty
  • 3,917 Thanks
  • 4,223 posts
Posted October 29, 2015 - 10:14 PM
I have to take them off to mount my tiller. The one in my avatar pic. As soon as the tiller comes off, the three point goes back on. I found a pic of a NH with the same setup. I am guessing that it is a Sperry design.
#11 wvbuzzmaster OFFLINE
  • 4,496 Thanks
  • 7,345 posts
Posted October 29, 2015 - 10:20 PM
Absolutely. Hey Eric, chance you can get a center of ball to center of ball dimesion on those lower arms? Also the lift link length center of eye to center of eye as you have them set currently. Might help me find something to use off other stuff or build my own arms similar to OEM.
Edited by wvbuzzmaster, October 29, 2015 - 10:21 PM.
#12 shorty ONLINE
shorty
  • 3,917 Thanks
  • 4,223 posts
Posted October 30, 2015 - 04:57 AM
I can do that. Might be a day or two until I get back to it.
#13 KennyP ONLINE
  • 29,571 Thanks
  • 40,547 posts
Posted October 30, 2015 - 05:31 AM
Casey, you might want to look here. They have the weld ball ends (CC-36-002) that I use. Also, a set of arms that look similar to what Eric posted (CC-03-006).
  • limebuzz and wvbuzzmaster have said thanks
