PVC Greenhouse
26 replies to this topic
#1 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted October 27, 2015 - 07:01 PM
Plan to do a 12-14' by 40' PVC greenhouse. Anyone done one?
  • oldedeeres said thank you
#2 Robert Webb OFFLINE
Robert Webb
  • 907 Thanks
  • 429 posts
Posted October 27, 2015 - 07:10 PM
What size pipe do you plan to use?
  • Firefighter912 said thank you
#3 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted October 27, 2015 - 07:13 PM
3/4"x 10' conduit cut into then 3/4"x 5' cross section for support.
Rebar Will be hammered in ground and PVC slide onto it with boards at the bottom for bracing with pipe clamps holding on to it
Edited by Firefighter912, October 27, 2015 - 07:14 PM.
#4 cootertom ONLINE
cootertom
  • 1,599 Thanks
  • 829 posts
Posted October 27, 2015 - 07:29 PM
Friend did one out off 1" pvc. Wind got it about 3 years later.
  • boyscout862, oldedeeres and Firefighter912 have said thanks
#5 Alc ONLINE
  • 6,912 Thanks
  • 7,472 posts
Posted October 27, 2015 - 07:53 PM
Do a web search , I thought I read that you just need to paint or cover the pvc because it attaches the plastic film if left on for a long time . I use pvc hoops over my raised bed for the winter and haven't had any issues but I take it off most of the year
  • grnspot110, oldedeeres and Firefighter912 have said thanks
#6 glgrumpy ONLINE
  • 8,622 Thanks
  • 7,926 posts
Posted October 27, 2015 - 07:55 PM
Hope not building NOW! Cold makes PVC snap easy when smaller sizes used. Think I wold go up some in size if mine. I hate plastic sheeting and tarps for anything one wishes to last.  I laugh when I see ads for those One-car plastic garages and bet they won't last 1/2 a winter as sold.
#7 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,341 Thanks
  • 9,800 posts
Posted October 27, 2015 - 08:10 PM
I made a frame out of a trampoline frame; a half circle on each side with the leg sockets connected by 2x2s. I anchored the whole thing with rebar and covered it with a tarp and bungee cords. A strong wind lifted it 10 ft. in the air and sent it flying.
  • Alc, boyscout862, oldedeeres and 1 other said thanks
#8 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted October 27, 2015 - 08:22 PM
Well I'm in south Georgia so its still warm here..60* to 80* right now.
I'm thinking I will use some PVC cover pieces,that you use to wrap PVC up during the winter. I will place them in different locations to keep the PVC from touching the film.
I'm also thinking about more mounting options,to prevent wind blowing it away. More than likely I will remove the film during our summers since its,hot like hell down here then
#9 oldedeeres ONLINE
oldedeeres
  • 9,543 Thanks
  • 4,782 posts
Posted October 27, 2015 - 08:42 PM
I am planning on building a frame work for bird netting out of PVC to protect the hascap and sea buckthorn bushes next year. Hadn't thought about using rebar to anchor it. Thanks for the tip. Since it will not be solid walled plastic I won't have to worry about the wind taking it away, but I do wonder about the PVC and sun damage. Should be fairly easy to take down if it looks like the pipe is deteriorating after a while though.
#10 boyscout862 OFFLINE
  • 12,867 Thanks
  • 9,179 posts
Posted October 27, 2015 - 09:35 PM
I'm putting up a used Shelter Logic tent garage. The PO had it up for 16 years. It is still in fair condition. I hope to fit 15 GTs or other toys into it for the winter. I will be tying the frame down to the tractors in atleast 12 places. I will also throw 3 lines over it and ty them down so that the tarp cannot billow up and rip.
It uses 11/2" steel pipe and even it bent a little under last winters' snow. Good Luck, Rick
Edited by boyscout862, October 27, 2015 - 09:38 PM.
#11 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Mine isn't that big its about 12' or 15' long 7' wide 3/4" pvc. Needs to be covered but is pretty sturdy right now. I have heard about pvc touching the film but have seen peoples that have been up a while and they have pvc touching the film.
  • Alc, oldedeeres and Firefighter912 have said thanks
#12 BTS ONLINE
BTS
    Make Stuff Up
  • 4,270 Thanks
  • 2,463 posts
Posted October 27, 2015 - 09:36 PM
We built a 12' X 24' greenhouse out of PVC, we used 1 inch pvc on 4' tall walls with dirt piled against them. You will half to cover the PVC pipe with something, if not, after one season the greenhouse plastic will fall apart. Ours has withstood 80mph winds and it didn't phase it. We have used this for 2 seasons and it has worked great.
Since your greenhouse is going to be that big, I would recommend using 1 1/2" pvc
  • Alc, Bud W, sacsr and 4 others have said thanks
#13 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted October 27, 2015 - 09:56 PM
Where do Yall get your greenhouse film
  • BTS said thank you
#14 BTS ONLINE
BTS
    Make Stuff Up
  • 4,270 Thanks
  • 2,463 posts
Posted October 27, 2015 - 10:04 PM
Greenhouse Mega Store
That's where I get all my greenhouse supplies at.
Edited by BTS, October 27, 2015 - 10:26 PM.
  • Alc, dlang94 and Firefighter912 have said thanks
#15 EricFromPa ONLINE
EricFromPa
  • 3,672 Thanks
  • 3,118 posts
Posted October 27, 2015 - 11:55 PM
Wonder how well Pex tubing would hold up.It's pretty rigid and should hold up really good in cold weather.They make it up to 1 1/2" in 100ft rolls for around $100.
Here Ebay 1 1/2" Pex tube
http://www.ebay.com/...SPR-XGz-rqe1GDQ
and 300ft of 1" for $165
http://www.ebay.com/...cEAAOxydlFSxtzl
Mom wants me to build her a small greenhouse for herbs and seedlings next spring.
Edited by EricFromPa, October 28, 2015 - 12:01 AM.
