Tire went bad, can't get one quick, what do you do ?
12 replies to this topic
#1 propane1 OFFLINE
propane1
  • 9,476 Thanks
  • 4,408 posts
Posted October 27, 2015 - 10:01 AM
You fix it. Wire, foam, small drill and some goop. Put the foam in and sew up with the wire, coat inside with goop to help protect the tube. Hope fully it works. Tire had a bugle in the side for a long time, then went flat. The wire bead broke out of the rubber on the tire and wore a hole into tube. This is on the tractor with the loader. Noel
  • wvbuzzmaster, CRFarnsworth, Traill95 and 8 others have said thanks
#2 HDWildBill OFFLINE
  • 8,984 Thanks
Posted October 27, 2015 - 10:11 AM
Nice repair.  I was going suggest shoe goo works well in cases like that and holds up quite well.  I just fixed a wheel on the lawn sweeper with shoe goo.
  • boyscout862 and propane1 have said thanks
#3 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,489 Thanks
  • 4,588 posts
Posted October 27, 2015 - 10:18 AM
Ummm, I would be interested to know how well this holds with a load in the bucket. :watch_over_fence: I can visualize the wire bead repair failing and a basket ball size bubble from the tube before "BOOM!" and :mad2:  :wallbanging:  :shoot3: . If it holds, Cool repair! :dancingbanana: , good job. :wave:
  • propane1 said thank you
#4 propane1 OFFLINE
propane1
  • 9,476 Thanks
  • 4,408 posts
Posted October 27, 2015 - 10:56 AM
It held all the loads before tube went flat. Hopefully it holds. Can't get that tire in my area any more. Noel
Tire back on rim. 20 psi. Bad part of tire is where the nipple is pointing to.
#5 Jazz ONLINE
Jazz
  • 2,678 Thanks
  • 1,550 posts
Posted October 27, 2015 - 11:49 AM
Good luck with that.. I'm thinking the bead let go in one area,,,next week it will be some other area of tire. How 'bout putting a crutch on the rim so it hops over the weak spot of tire :rolling:
#6 propane1 OFFLINE
propane1
  • 9,476 Thanks
  • 4,408 posts
Posted October 27, 2015 - 12:39 PM
 Jazz, good idea.   Noel
#7 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,643 Thanks
  • 2,618 posts
Posted October 27, 2015 - 03:56 PM
Looks like a good repair to me, I'll keep it in mind!
#8 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,927 Thanks
  • 6,384 posts
Posted October 27, 2015 - 04:22 PM
Couldn't you of taken a piece of old tube, layered it around the inside of the bead, and inflated the new tube?
Looks good.
#9 propane1 OFFLINE
propane1
  • 9,476 Thanks
  • 4,408 posts
Posted October 27, 2015 - 04:46 PM
Could have. Great idea. But I didn't think of that. Noel.
  • toomanytoys84 said thank you
#10 chieffan OFFLINE
  • 11,395 Thanks
  • 7,130 posts
Posted October 27, 2015 - 05:02 PM
Gtractor gave me the idea of inflating the tube to the size it is inside the tire.  Then wrap the tube with 4 or 5 layers of  Duct tape wrapped around the tube where the week spot is on the tire.  Put it all back together and go.  I did that with front tube on a RAM.  Had the duct tape showing in a soft ball size hole in the tire.  Ran 6 lb in it and it held for 3 or 4 months and was holding when I sold the tractor.
#11 karel OFFLINE
karel
  • 2,339 Thanks
  • 1,499 posts
Posted October 28, 2015 - 04:43 AM
That to me looks to be done by someone who lives way out in the middle of nowhere and knows how to get it done. and has no choice but to do so!
Edited by karl, October 28, 2015 - 04:44 AM.
#12 toppop52 OFFLINE
toppop52
  • 5,547 Thanks
  • 4,907 posts
Posted October 28, 2015 - 06:27 AM
That looks like some of the stuff I do just to say I fixed it, even if a new one was across the road! :D
#13 HANKG OFFLINE
HANKG
  • 6,597 Thanks
  • 3,530 posts
Posted October 28, 2015 - 07:16 AM
I like your painting in the third picture if it were mine I'd hang it on the wall and give it a name. THE REPAIR LOOKS GREAT ALSO.
Edited by HANKG, October 28, 2015 - 07:22 AM.
