* * * * - 5 votes
Bolens Model 1000 Seat Recover Project
106 replies to this topic
#31 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22798 Thanks
  • 7538 posts
Posted November 08, 2015 - 07:18 PM
While waiting on the white vinyl I decided to try sewing up a test cover for the bottom cushion.  Tried to shape a piece of vinyl around the corners and it puckered quite a bit so I decided to add a few extra seams.  I will probably use a welt in the u shaped seam that runs from the back around the front and to the back again.  Got the spacing on the pleats a little wide and the front seam is not quite right but here are the results.
  • limebuzz, Alc, Bruce Dorsi and 1 other said thanks
#32 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22798 Thanks
  • 7538 posts
Posted November 08, 2015 - 07:22 PM
Then I decided to try making a test cover for the back piece - got the pleat spacing fairly close but did an oops and added an extra pleat at the bottom.  Here are the results and a test fit of both cushions on the modified seat pan with some clamps.
  • Alc, Bruce Dorsi, blackjackjakexxix and 2 others have said thanks
#33 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted November 08, 2015 - 08:13 PM
I really think your making good head way,really looking good
  • Austen said thank you
#34 Austen OFFLINE
Austen
  • 3722 Thanks
  • 1470 posts
Posted November 09, 2015 - 12:21 AM
Ditto! He could've made these for Bolens back in the day.
Edited by Austen, November 09, 2015 - 11:43 AM.
  • Alc and 29 Chev have said thanks
#35 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted November 09, 2015 - 08:39 AM
Excellent work!!!!
  • 29 Chev said thank you
#36 Tbrooks OFFLINE
Tbrooks
  • 523 Thanks
  • 330 posts
Posted November 09, 2015 - 10:30 PM
Made a covering for the two rods on the back by using some white 3/4" pvc pipe with a slit cut in it and a couple of modified pvc elbows - bent the pvc pipe with the help of a heat gun.  Could cover the back with the white vinyl and then put the pipe and ends over top.  I am going to wait until the white vinyl I have on order shows up and see if I can come up with another solution that will look more the same as the original back but this is one option that I came up with.
I might have a suggestion. I do crazy stuff with plastics on a daily basis at work. Try filling the pvc tube with sand, heat it and bend it. Then cut the slot in using a router table. You may get a cleaner bend.
  • blackjackjakexxix and 29 Chev have said thanks
#37 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22798 Thanks
  • 7538 posts
Posted November 10, 2015 - 08:49 PM
Made up a new bottom cover after I got the pleat spacing figured out.  I modified the outer seam by moving it in about 3/8" along the sides at the back so it will line up better with the rear cushion seam and added piping to the seam which gives it a more finished look (in my opinion).  I sewed two pulls at the front and some at the rear on the bottom to get it to form the shape around the foam cushion without having to glue it to the foam.  Here are pictures of the result.
  • Bolens 1000, Alc, blackjackjakexxix and 1 other said thanks
#38 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted November 10, 2015 - 08:57 PM
Dang Stew,that looks SUPER !!!!
#39 Chubien OFFLINE
Chubien
  • 648 Thanks
  • 399 posts
Posted November 10, 2015 - 09:47 PM
Nice work, I'm thinking that seat will be too nice to put on the tractor!
Hopefully I get a chance to get the 1000 looking better over the course of winter
#40 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22798 Thanks
  • 7538 posts
Posted November 11, 2015 - 09:21 PM
Not sure that it will be too nice for your tractor - time will tell.  While seats should look nice and tractors can be made showroom condition I think lawn tractors can be made to look good and still be used for the purpose they were intended giving us pride and enjoyment of ownership in multiple ways.
#41 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22798 Thanks
  • 7538 posts
Posted November 11, 2015 - 09:28 PM
Sewed up a new back cover - here are the results.  I think I have the seams lining up fairly well now and the covers appear to be fitting not bad (in my opinion).  Hopefully the white vinyl will show up soon and I can tackle the back and then join the back and front together in a happy marriage around the outer edge.
  • Alc and Bruce Dorsi have said thanks
#42 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted November 11, 2015 - 09:37 PM
Coming along nicely!
 Are you sure you didnt work in Bolens seat division years ago? :poke:
#43 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22798 Thanks
  • 7538 posts
Posted November 11, 2015 - 09:53 PM
Thanks for the kind words.  Perhaps in a former life as I would have been about 10 years old when this seat was designed and sewed together the first time back in 65.
#44 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted November 11, 2015 - 10:46 PM
Wow Stew,really looking good,Thanks for all the time with this one
#45 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22798 Thanks
  • 7538 posts
Posted November 15, 2015 - 07:24 PM
Decided to rework the outer edge of the seat pan so I would have an open area to staple and sew the back to the front.  Trimmed the lip so it 1/4" wide and then I used some 1/8" round rod about 3/4" long and welded pieces to the 1/4" lip of the seat pan about every two inches.  Then I welded a 1/4" ribbon of sheet metal to the 1/8" rod to provide an outer edge - if I was doing it again I would use 1/8" rod to make the outer edge as it would be just as strong and easier to work with.  Once I was done welding I gave it a quick paint job.
  • limebuzz, blackjackjakexxix and have said thanks
