Simplicity Sunrunner carb/fuel system/ignition problems
2 replies to this topic
#1 bwortley50 OFFLINE
bwortley50
  • 1 posts
Posted October 25, 2015 - 01:32 PM
I have a sunrunner,my second,and it is going to be a restoration project but will used to mow also. I am having problems with it completely filling the carb with fuel. I am going to do a carb rebuild but it just seems impossible for it to put that much fuel in the carb. The float and float valve seem to be fine. Also the ignition switch was gone and I got a universal switch. When I have got it to run long enough to check, I'm not getting the correct wires to have voltage according to the schematics I've downloaded. Any help would be appreciated! I don't know what year it is but the model number is 1691458. 12hp Briggs I/C 42" deck 5 speed.
#2 overhaul OFFLINE
overhaul
  • 1 posts
Posted May 12, 2016 - 01:25 PM
Have you checked your fuel pump to ensure that its the correct one for your motor?
Have you checked to see if your fuel shutoff solenoid on the bottom of your carb hasn't been removed and is operating properly?
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted May 12, 2016 - 03:03 PM
:welcometogttalk: :camera:
