Caption This! 10-24-15
18 replies to this topic
#16 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted October 24, 2015 - 05:37 PM
Thought photoshop at first, then looked close. WTH did that come from!!!!! Clean shorts needed for sure, looks more like a cog rather than a saw blade. I am guessing if it was a "sharp" blade there would have been two vehicle halves.
That is a diamond blade for saw cutting concrete and a big one at that! Glad no one was hurt.
The cogs have man made diamonds embedded to grind away at the concrete/stone/rebar; water is typically used as a cooling medium to prolong blade life. Blades that big are sold in the USA by diamond count per inch. Rule of thumb ~ $100+ an inch. That is one expensive blade that was ruined as the segments themselves are likely bent and could fly off. I never used one that big; but had one self destruct in my construction years.
  • oldedeeres said thank you
#17 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,219 Thanks
  • 2,271 posts
Posted October 24, 2015 - 06:22 PM
Worked better in the Bond movie    . :D    Rick ​
#18 oldedeeres OFFLINE
oldedeeres
  • 10,672 Thanks
  • 5,171 posts
Posted October 24, 2015 - 11:11 PM
Some of the roads up here are rough enough to jar parts loose too!
  • Bmerf said thank you
#19 UncleWillie OFFLINE
  • 16,415 Thanks
  • 9,030 posts
Posted October 24, 2015 - 11:18 PM
Just trying to give the ex her half.
