Picked up the 1050
38 replies to this topic
#31 Rainier OFFLINE
Rainier
  • 682 Thanks
  • 557 posts
Posted October 24, 2015 - 10:16 AM
Thanks guys, for all the info. I re read the tube frame article again and figured out what I have.
Does anyone have pics of how the scraper blade mounts up?
#32 Diesel1050 OFFLINE
Diesel1050
    Diesel Nut!
  • 381 Thanks
  • 419 posts
Posted October 24, 2015 - 10:23 AM
LOVE that Highboy! Only factory produced pickup to have fully hydraulic steering!
  • Austen and Rainier have said thanks
#33 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted October 24, 2015 - 10:31 AM
This is the only literature i have found for these
http://gardentractor...ade-for-bolens/
  • Rainier and Paulgo have said thanks
#34 Rainier OFFLINE
Rainier
  • 682 Thanks
  • 557 posts
Posted October 24, 2015 - 01:42 PM
Thanks doc. I looked thru all my service manuals and could not find anything. I do have a lot of manuals that cover a wide range of tractors and add on's. Such as power steering, oil coolers, head light kits, push mowers, snow casters , three point hitches ect.....
Keep that in mind if there is something you may need.
#35 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1179 Thanks
  • 697 posts
Posted October 25, 2015 - 11:58 AM
That makes sense the early PM142 and PM161 spring rated the engines up to 2900rpm , the PM200A which was common on most engines after 66' says 3600rpm
Does that mean you could increase your horsepower on these motors by changing the governor spring, or is there more to it than that?
Thanks, Jim
#36 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted October 25, 2015 - 02:48 PM
The TRA10D had a longer stroke than the TR10D giving you the extra 2HP
  • CanadianHobbyFarmer said thank you
#37 Rainier OFFLINE
Rainier
  • 682 Thanks
  • 557 posts
Posted October 25, 2015 - 07:45 PM
So can you change the crank and rod to get the extra 2hp
#38 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1179 Thanks
  • 697 posts
Posted October 25, 2015 - 10:29 PM
Thanks. I was referring to Bruce's comment on uprating the tr-10-d's and your reply regarding the rpm rating on the springs. I am not looking for more power out of mine, I was impressed with it before the head gasket finally gave up From what everyone tells me on here, I should amazed by the power when I get the new gasket installed
Thank, Jim
#39 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted October 26, 2015 - 08:02 AM
Thank, Jim
I guess if you increased the RPM's you'd get a bit more HP input but they did these things for a reason so I wouldnt recommend using the PM200A in the older engines.
