Tiller depth question
54 replies to this topic
#31 propane1 ONLINE
propane1
  • 8,721 Thanks
  • 4,126 posts
Posted October 24, 2015 - 03:07 PM
Left tines are on wrong. That is your extension side. ?? Noel
  • backwoods said thank you
#32 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted October 24, 2015 - 03:32 PM
Yes the extension is on the left
  • propane1 said thank you
#33 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted October 24, 2015 - 04:07 PM
I agree, the extension tines are on backwards. You also have the lift bar on backwards as well. You need to swap it end to end. The part that you are showing actually hooks to the tiller, and not the lift carriage.
#34 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted October 24, 2015 - 08:03 PM
Thanks Troy I tried it the other way an it didnt seam right so i set it up this way. Is there a manual for this some where's or at least pictures?
#35 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted October 25, 2015 - 09:42 AM
no how do i set it for the max depth for tilling? should the rear tires be on blocks?
#36 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted October 25, 2015 - 12:15 PM
I hope these will help you and turn out alright:
Keep us posted on the results!
  • shorty and backwoods have said thanks
#37 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted October 25, 2015 - 12:34 PM
The second picture on the right top is blurry but i have ageneral idea on how to set it up so maybe today ill fiddle with it an  flip the lift bar an the tines around an give it one last shot before the weather turns.
#38 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted October 25, 2015 - 06:42 PM
Well here are some updated pics thanks again Troy for the pics from the manual on how to set it up.uploadfromtaptalk1445816493018.jpg uploadfromtaptalk1445816507535.jpg uploadfromtaptalk1445816520612.jpg
  • johndeereelfman and shorty have said thanks
#39 shorty ONLINE
shorty
  • 5,477 Thanks
  • 5,260 posts
Posted October 25, 2015 - 06:54 PM
Once you have set right it will do some serious tilling. I have a similar one on my Gravely with two extensions. One time I measured how deep it was digging, I had 9" of loose dirt.
  • johndeereelfman and backwoods have said thanks
#40 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted October 25, 2015 - 07:25 PM
Much better Greg! You should be good to go now.  :thumbs: Glad I could help out.
  • MH81 and backwoods have said thanks
#41 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted October 25, 2015 - 08:01 PM
I'm thinking of going to setting A though for more depth an the ground Is still hard under the lose stuff
#42 shorty ONLINE
shorty
  • 5,477 Thanks
  • 5,260 posts
Posted October 26, 2015 - 12:29 PM
That's the setting I am using. I thought it seems to drag more stalks along. Kind of piles up in the middle. Not enough that I am ready to switch to a shallower setting.
#43 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted October 30, 2015 - 12:38 PM
Ok so now that I used it the right way it worked great for 10ft then stopped I'm guessing I broke a shear pin? If so where is it located pics for year down will help thanks in advance.
#44 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted October 30, 2015 - 01:28 PM
Here is how far I dare tear down
#45 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted October 30, 2015 - 02:36 PM
Now that the top sprocket is off I see that it is a clutch system. Who sells the friction disc for the tillers?
