Original parts
8 replies to this topic
#1 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted October 21, 2015 - 02:52 PM
My rear axle bushings were really shot, one was sticking partly out, so I decided to disassemble and see what needed replacing. I usually find parts on eBay but haven't found this one. Does anyone on here sell or know where to order this part? IH-376160-R1 is the bushing part number, and I was thinking of replacing the oil seal since I have it apart (IH-610465-C91). Anyone else who has done this and has suggestions or tips they're welcomed.
Edited by dlang94, October 21, 2015 - 03:38 PM.
#2 Bolens 1000 OFFLINE
  • 14,983 Thanks
  • 18,140 posts
Posted October 21, 2015 - 05:37 PM
Dont have those numbers interchanged yet.....
Any cub cadet dealer near you can get them, they are both current part numbers
#3 boyscout862 OFFLINE
  • 12,831 Thanks
  • 9,158 posts
Posted October 21, 2015 - 05:40 PM
25 years ago I rebuilt an original Cub Cadet with off the shelf parts from a bearing distributor in Hartford, CT. I took the old bearings and seals in and we measured them. Two bushings had to be trimmed but the rest fit. Good Luck, Rick
  • dlang94 said thank you
#4 Bolens 1000 OFFLINE
  • 14,983 Thanks
  • 18,140 posts
Posted October 21, 2015 - 05:52 PM
:ditto:
If there is  bearing and seal guy near you try them
Worst comes to worst ship me your old stuff and I'll interchange them for you.
  • Alc, boyscout862 and dlang94 have said thanks
#5 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted October 21, 2015 - 08:14 PM
I found all of it at ccspecialties.org, a shifter knob too.
#6 dodge trucker OFFLINE
dodge trucker
  • 2,423 Thanks
  • 3,116 posts
Posted October 22, 2015 - 12:12 PM
Yup more gt parts can be sourced at a bearing supply house than many realize, especially on the older machines.
#7 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted October 27, 2015 - 08:40 AM
Got it all back together, used tractor supply TRAVELLER UNIVERSAL TRACTOR TRANS/HYDRAULIC FLUID. No more leaking and rolls smoother with the new bushings.
  • olcowhand said thank you
#8 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted October 27, 2015 - 02:52 PM
I was attempting to grease the rear axles and broke one of the fittings, the other one doesn't seem to work right either. From what I can find they're drive type fittings, how do I remove them?
#9 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted October 27, 2015 - 08:36 PM
The one that was broken off drilled out easy, broke the other one and it drilled out too. The bushings had a hole to line up with the grease fitting that I didn't think anything of so I drilled through the bushing and it came out smooth where the axle touches the bushing.
