what causes this?
8 replies to this topic
#1 Sdhdcouple OFFLINE
Sdhdcouple
  • 143 Thanks
  • 153 posts
Posted October 21, 2015 - 01:58 PM
what would cause this?  the white milky / foamy stuff
https://www.youtube....eature=youtu.be
#2 olcowhand ONLINE
  • 37,446 Thanks
  • 30,271 posts
Posted October 21, 2015 - 02:03 PM
Moisture in the block/oil.  Normal to a point.  Running engines for short periods without reaching full temps will cause a buildup of moisture.  Long run times will rid the engine of moisture better.
  • grnspot110, Alc, Sdhdcouple and 1 other said thanks
#3 Sdhdcouple OFFLINE
Sdhdcouple
  • 143 Thanks
  • 153 posts
Posted October 21, 2015 - 02:42 PM
ok thanks, just wanted to check
#4 Bill 76 ONLINE
Bill 76
  • 1,776 Thanks
  • 1,124 posts
Posted October 21, 2015 - 02:48 PM
Water is a byproduct of combustion and as cowhand said running for short periods will cause it to build up,got to run em up to temp to boil it out.
It that the breather it's coming out of ? it does seem excessive though --does your oil look like a milk shake ? if so drain it now , oil and water will mix and is not a very good lubricant.
  • Marty'70 said thank you
#5 Marty'70 OFFLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 825 Thanks
  • 695 posts
Posted October 21, 2015 - 03:31 PM
Is it possible it sat outside in the rain and could have seeped into the crankcase? It needs gone however it got in there.
  • Bill 76 said thank you
#6 Sdhdcouple OFFLINE
Sdhdcouple
  • 143 Thanks
  • 153 posts
Posted October 21, 2015 - 03:59 PM
ya I am going to change it. between the issues of one side not firing for who knows how long, sitting out side all summer and not knowing the history of the machine. I am just going to change the oil.  Seemed a little on the then side when I drained it.  So I change it and see if it quits.
thanks everyone
#7 LilysDad ONLINE
LilysDad
    --Crazy about GTTalk-- 'sort of'
  • 11,186 Thanks
  • 8,522 posts
Posted October 21, 2015 - 06:23 PM
When you were a kid, did you ever pull out the dipstick on your dad's mower and pee in it?  No. . .       I suppose not.
#8 Marty'70 OFFLINE
Marty'70
  • 825 Thanks
  • 695 posts
Posted October 21, 2015 - 08:23 PM
Wow! Someone was mad at their dad huh???
#9 LilysDad ONLINE
LilysDad
  • 11,186 Thanks
  • 8,522 posts
Posted October 21, 2015 - 08:44 PM
What? Wasn't me! Nope!!!
