Bolens 1886 replacement seat
5 replies to this topic
#1 Bud W OFFLINE
Bud W
    old member
  • 520 Thanks
  • 407 posts
Posted October 21, 2015 - 11:53 AM
Does anybody know where I can find a good replacement seat (part number) for one of my 1886's? I see many on Ebay but none listed for the old Bolens.
#2 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5112 Thanks
  • 1215 posts
Posted October 21, 2015 - 05:44 PM
Hello, I've put this seat on a couple of my '86 's and it's pretty close size wise to original, not to bad looking,comfortable, to bad not available in Brown, I'll check fitment and get back to you, but I believe it was a direct bolt on if you have the seat bracket with the arch spring, here's some pics of one I put it on.
http://gardentractor...ey-goose-86-01/
http://www.ebay.com/...0B-OHhX0TI_EPLw
  • wilberj and Bud W have said thanks
#3 Bud W OFFLINE
Bud W
    old member
  • 520 Thanks
  • 407 posts
Posted October 23, 2015 - 01:44 PM
Does it have a metal pan or is it plastic?
#4 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5112 Thanks
  • 1215 posts
Posted October 23, 2015 - 04:58 PM
The ones I used have metal pans with the beefed up drilled and tapped bushings for bolting the bracket to the seat (or vise-verse)
Here is a pic of the tag off of one of them.
  • Bud W said thank you
#5 Bud W OFFLINE
Bud W
    old member
  • 520 Thanks
  • 407 posts
Posted October 26, 2015 - 09:02 AM
Thanks, that's what I needed.
#6 Deerlope OFFLINE
Deerlope
  • 819 Thanks
  • 483 posts
Posted October 26, 2015 - 09:39 AM
If you plan on spend very much time in the seat look for one with a high back. I have found this seat to be very comfortable. I am almost sure that I did not pay that much for them either. It has a steel base with many different holes drilled and tapped. I have one on my 1455 at present.
http://www.tractorsu...ck?cm_vc=IOPDP1
Edited by Deerlope, October 26, 2015 - 09:52 AM.
  • Husky said thank you
