Massey Ferguson 8 hp
132 replies to this topic
#76 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted July 03, 2016 - 10:08 PM
I will be near the 8 tomorrow, can you post a pic of the area in question?
#77 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted July 04, 2016 - 08:29 PM
We're you able to define what you need info on with a pic? I'll be leaving in an hour and won't be up for a couple days
#78 Sugarmaker OFFLINE
Sugarmaker
  • 240 Thanks
  • 181 posts
Posted July 05, 2016 - 10:30 PM
DMAX, Folks,
Tthanks for checking in on me. Couple steps forward and a few back today on the little Massey.
I must say just getting it cleaned up with some fresh paint does make it look better. I will try to post some pictures tomorrow of the progress. I realized today that the right tunnel cover for a standard shift is a couple inches longer than a hydro. Forgot to check that!
So back to the weld shop for layout, cutting, grinding and sanding. Then to the giant paint booth for new gray! Tonight it looked so good next to the other tunnel cover, I had to spray that again too! Hope the bugs don't bother it!
I did get the headlights mounted and hope to get the tail light mounted tomorrow. couple trips to NAPA and the hardware storr for fasteners. Plus lots of little moves.
MH81 I have so many questions I may not remember what I need. But my biggest issue is how to wire up this engine? HELP! Need some one to talk me through this.
Must get rest now!:)
Regards,
Chris
#79 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted July 06, 2016 - 04:54 AM
Chris, I think I will be going up to the farm tonight, depends on what hits the fan today.
I will send you some contact info in a minute. Hope it's a question I can answer, our 8 doesn't have headlights.
  • Sugarmaker said thank you
#80 Sugarmaker OFFLINE
Sugarmaker
  • 240 Thanks
  • 181 posts
Posted July 06, 2016 - 08:54 PM
Folks,
 Slow progress today on the Massey project. Took the engine shroud off to show my neighbor the current electrical system. Was able to install the tail light and rear fender decal. Of course I had problems with both. Got a masking tape mark on one half of the tunnel. Just that type of day!
Did get some pictures just too pooped to post!:)
Hope some Massey folks come to the Pioneer Steam and Gas Engine Society tractor show next week in Sagertown PA.
Regards,
 Chris
  • limebuzz said thank you
#81 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted July 06, 2016 - 09:14 PM
Current plan is the MH50 with planter and Ryans 10. Don't think I can get any attachments for the 10 on the load.
Did you get your wiring fixed?
I sent you a Pvt Message but don't think you've read it yet
  • DMAX and Sugarmaker have said thanks
#82 Sugarmaker OFFLINE
Sugarmaker
  • 240 Thanks
  • 181 posts
Posted July 07, 2016 - 09:57 PM
 Thanks i read it but have too swamped to call you! I will be trying to complete the wiring tomorrow. Since it doesnt matach the original wiring diagram I will be winging it. Which usually means trouble when it comes to electrical. May have to just push it around  the show!:)
I did order $60.00 more Massey decals for the milk cans today.
Here are some pictures I promised. Remember this is just a clean up and paint.
foot grips saved and will glue in place
Maple Hunter Decals
right tunnel cover for std shift had to be modified after it had been painted.
Choose to use this original seat.
Decal applied to hood front.
attached data plate.
tail light. (of course I installed it upside down and had to re do it.)
Steering wheel and knobs got a coat of black Krylon
Right tunnel cover after mods from the weld shop and now aging in the giant paint booth!
We plan to have lights!
not glued yet!
Starting to see the little tractor take shape.
this is the module under the blower shroud.
Engine in place. I had a heck of a time getting engine bolts in. very tight without tasking the mower drive unit off.
Thanks for checking in on me! We might just make it!
Any suggestions on the wiring would be great!
Regards,
 Chris
#83 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted July 07, 2016 - 10:06 PM
Ok, now that I see what you mean, I can look tomorrow and see if there is any help.
There may be a line just for the lights, which our crusty monkey doesn't have.
#84 zippy1 OFFLINE
zippy1
  • 638 Thanks
  • 389 posts
Posted July 07, 2016 - 11:41 PM
Looks good from here Chris. I'd let you park it next to my "O" at a show... :thumbs:
#85 Sugarmaker OFFLINE
Sugarmaker
  • 240 Thanks
  • 181 posts
Posted July 08, 2016 - 10:31 PM
Thanks guys!
Appreciate the help tonight MH81. Looking forward to meeting you at the tractor show next week.
Progress of sorts. installed the dash which had a scratch in it. Realized that the choke and throttle levers were installed in wrong place. So took the dash back out and painted it again.
Added all the decals that i could to the tractor. They look pretty good, some pesky air bubbles!
Regards,
 Chris
#86 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted July 08, 2016 - 10:56 PM
We had an engine similar to that on our log splitter.
I have no idea what spark system you have tho, it's different in that regard
On that engine, the green wire went to the ground to kill switch.
#87 Sugarmaker OFFLINE
Sugarmaker
  • 240 Thanks
  • 181 posts
Posted July 09, 2016 - 05:50 AM
Alan,
 Thanks! I am sure when I get it figured out it will be simple enough. Just trying not to fry the system! I thought I was going to use the wiring from the Massey 7 parts tractor which looked to be more complete. So in hind site I did not do a good job of marking the wires coming out of the engine. :(
Well I have a few more details befor I get to that spot, and should be able to start the tractor and check some things prior to final electrical connections.
I am off to hunt for pictures of how the choke cable mounting bracket was done on a 8 hp Tec.
After working several hives of bees yesterday afternoon I was whipped!:)
Will try to get some additional progress pictures today too.
Regards,
 Chris
#88 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted July 09, 2016 - 06:05 AM
These might be of help
#89 Sugarmaker OFFLINE
Sugarmaker
  • 240 Thanks
  • 181 posts
Posted July 09, 2016 - 06:12 AM
Will,
I have a different engine which has a different throttle attachment system. And My intake does not have the cast feature with the tapped hole for the choke bracket. But this will help on the choke bracket location. I am going to have to fab one that looks better than it was rigged when i got it. That picture sure helps. I will let you know how I end up. Need to get out in the garage before the heat.
 Regards,
 Chris
  • limebuzz and MH81 have said thanks
#90 Sugarmaker OFFLINE
Sugarmaker
  • 240 Thanks
  • 181 posts
Posted July 09, 2016 - 09:54 PM
Folks,
We had a good day on the Massey project. Good thing since I need to take it to Sagertown tractor show Wednesday!
I tackled the choke bracket first and built a bracket coming off the outer intake mainfold bolt. I will get some pictures when I find the camera!
Completed the dash mounting and installed the steering wheel.
Assembled and mounted the grill.
Friend came over and we started the engine and found that the green wire coming from the engine is the kill (to ground) wire So this wire went on the OFF post on the switch. Next we checked the pink wire from the engine and got about 15 Vac reading. I think this is what MH81 said. Connected this to the "D" terminal.
Engine started right up, shut down worked and it seemed to be charging just a little too!:)
Installed the hood and wired in the head lights.
About the only thing remaining item is the four foot pads to be glued on the foot rests. and a strap for the hood.
Will get some photos.
Regards,
 Chris
  • DMAX, limebuzz, MH81 and 1 other said thanks
