* * * * * 1 votes
MF14 Tractor,Tiller,Plow,Deck **Updated with New Owner**
18 replies to this topic
#16 KBuzz OFFLINE
KBuzz
  • 81 Thanks
  • 41 posts
Posted November 04, 2015 - 05:29 PM
Well I messed with it a bit and I think it is something like a carb issue. I tightened the throttle cable but now it doesn't adjust to full throttle. It makes it about half way. I'm not sure what would happen if i forced it but I wasn't ready to find out yet lol. However if I push on the throttle leg on the carb that old dog still has a lot of bite! Now I don't want to blow the thing up, but it seems like with the lever stopping at around 1/2 throttle, that's exactly what it seems to be running at. I don't know maybe the cable is kinked somewhere? Now when I say lacking power, I say that because I have seen a 14 fly at top speed! I remember thinking to myself at no time would anyone need to go that fast! However, at the same time why not? lol. Also when I engage the mower, it seems to run a little ruff. Like if it was at a higher RPM it would smooth out.
#17 MH81 OFFLINE
  • 29,979 Thanks
Posted November 06, 2015 - 10:34 PM
Any improvement on this?
  • KBuzz said thank you
#18 KBuzz OFFLINE
KBuzz
  • 81 Thanks
  • 41 posts
Posted November 12, 2015 - 06:13 PM
Not much. The throttle linkage has a lot of play in it, I'm not sure if that where is my problem is or not. I need to do some reading before I start fooling with stuff I don't know much about. I also removed the hood and grill so I can start looking into fixing the hood hack job. At first I was planning on using my new MF for snow duty, since it runs. Now im thinking I should turn the major tear down and restore into an inside winter project.
Edited by KBuzz, November 12, 2015 - 06:17 PM.
  • MH81 and propane1 have said thanks
#19 MH81 OFFLINE
  • 29,979 Thanks
Posted July 08, 2016 - 06:34 AM
If you can get the power issue found and use her a little, you might be good to find any mechanical issues so you can address them during the refresh.
