Diesel motor
14 replies to this topic
#1 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted October 19, 2015 - 05:41 PM
Working on a project and trying to come up with a diesel motor for it in the 25hp range. Wondering if there were any ideas out there of what a good motor might be.
  • pharmer and jerryxw1 have said thanks
#2 chieffan ONLINE
  • 10,201 Thanks
  • 6,659 posts
Posted October 19, 2015 - 06:14 PM
Might look into one from a semi trailer cooling unit.  don't know for sure what hp they are but a friend put one on a GT and it has tons of power.  Had to have the adapter custom built.
#3 Jazz ONLINE
Jazz
  • 2,406 Thanks
  • 1,449 posts
Take a look for used reefer engines.. Lots of refrigerated trailers get wrecked annually and if you can source it from wrecker price could be decent depending on location.
#4 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted October 19, 2015 - 06:50 PM
Kubota D1105 if you have room is bullet proof..long as you NEVER use starter fluid on it.
#5 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted October 19, 2015 - 06:51 PM
pretty cheap on golf course units..(d1105)
#6 olcowhand ONLINE
  • 41,280 Thanks
  • 31,452 posts
Posted October 19, 2015 - 07:56 PM
The Kubota D1005 is also a good choice.
  • Auburn David said thank you
#7 pharmer OFFLINE
pharmer
  • 871 Thanks
  • 774 posts
Posted October 19, 2015 - 08:24 PM
I work at a truck salvage yard. I see these reefer engines every so often. I can inquire about one if you're interested.
  • boyscout862 and Auburn David have said thanks
#8 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted October 19, 2015 - 09:08 PM
I'm interested, but shipping might be expensive to Iowa I don't know that for sure
#9 michael.kitko OFFLINE
michael.kitko
  • 505 Thanks
  • 462 posts
Posted November 04, 2015 - 09:33 AM
Sorry to hijack the thread, I just saw this post, would you be willing to inquire about one for me possibly? I have always been searching for a small diesel and just have not found one yet. I don't think I am that far away from where you are.
#10 pharmer OFFLINE
pharmer
  • 871 Thanks
  • 774 posts
Posted November 04, 2015 - 10:49 AM
Sure...I'll find out today
#11 Diesel1050 ONLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted November 04, 2015 - 11:44 AM
We need to know about this project to suggest a proper engine. Torquewise, a diesel only needs to be about half the HP of a gasser to compare, also the reefer unit motors most often have permanently set governors, around 2200 RMP.
#12 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted November 09, 2015 - 07:12 PM
Looking at building a 4wd. Looking to pull a 2 bottom plow & not run out of power
  • olcowhand and limebuzz have said thanks
#13 lrhredjb OFFLINE
lrhredjb
  • 703 Thanks
  • 573 posts
Posted December 04, 2015 - 11:21 PM
I wonder if the lower rpm would adversely affect the operation of a mower deck? Mower decks seem to work better at higher rpms.
#14 KennyP ONLINE
  • 38,509 Thanks
  • 45,987 posts
Posted December 05, 2015 - 06:05 AM
Change pulleys around so you get mower speed back up!
#15 Cvans OFFLINE
  • 6,668 Thanks
  • 6,134 posts
Posted December 05, 2015 - 11:57 AM
Why the lower RPM's? Most if not all of the smaller modern diesels that I run are rated for 3600 rpm. I don't run them that fast except for the one in the golf cart but they are rated for it.
