My newest purchase!
44 replies to this topic
#1 KennyP ONLINE
  • 40,098 Thanks
  • 46,755 posts
Posted October 18, 2015 - 02:30 PM
Just got home with my newest tractor. I was surprised to come across it, but had to have it. It's a Model 450, been garage kept since new. Hasn't been ran in a couple years as it got to be too much for the little lady after her husband died. I'll be getting the rotary plow and snow blade for it real soon.
Check out the wheel weights!
  • Bolens 1000, olcowhand, DH1 and 12 others have said thanks
#2 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted October 18, 2015 - 02:36 PM
Looks good kenny you did good! Im not very familiar with gravely. So why so many levers? and what engine is that?
#3 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted October 18, 2015 - 02:37 PM
That looks like a beast. Nice find.  :thumbs:
I always wondered what was under the hood and are they light in the front?
#4 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted October 18, 2015 - 02:41 PM
That is awesome Kenny! What a score that was!!!! :thumbs: :dancingbanana:
#5 DH1 ONLINE
DH1
    Electric Tractors
  • 5,360 Thanks
  • 5,605 posts
Posted October 18, 2015 - 02:49 PM
Good Stuff Kenny I think those tractors pull real good with the engine in the back, lots of weight over the rear wheels.
#6 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,642 Thanks
  • 5,044 posts
Posted October 18, 2015 - 03:08 PM
Awesome "King of the 400 Series"
Gotta be from about 1971.  I would love to have a front drive kit on my 424 so I could run the rotary plow from a walk behind.
:thumbs:  :thumbs:  :thumbs:
#7 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted October 18, 2015 - 03:44 PM
Terrific and, likewise, wonder about all the levers, plus, what's under the hood?
#8 olcowhand ONLINE
  • 42,348 Thanks
  • 31,788 posts
Posted October 18, 2015 - 03:55 PM
Great looking tractor Kenny!  :thumbs:   Tractordata shows it as 16hp CCKA which are torque monsters!  The trans is unique sounding as I included excerpt from tractordata.com:
  Transmission: Transmission: Swiftamatic 8 Type: shaft-driven gear Gears: 4 forward and reverse Oil capacity: 5 qts [4.7 L] Oil type:   SAE 90W-EP Two-speed shift-on-the-move affects transmission and PTO speed. Additional two-speed range for transmission can be shifted only when stopped. Right-hand directional clutch lever controls forward and reverse.
  • DH1, Alc, KennyP and 2 others have said thanks
#9 KennyP ONLINE
  • 40,098 Thanks
  • 46,755 posts
Posted October 18, 2015 - 04:59 PM
Daniel answered the engine question. And the drive, which is the same (I believe) as the 2-wheel version. As far as all the levers, I'm still learning. We have a 400 series manual here, so check it out. I have downloaded it to study more in depth. I will be learning it as you folks are. I have gotten it to turn over, but I need to drain the 'shellac' out of the gas tank before I try to start it. The PO did install a fuel shutoff and it is off, so hopefully it will be easy to start! I can't wait to drive it.
Oh yeah, I think all 4 tires are nearly new. The rears still have the excess molding rubber between the treads.
  • Gtractor, Alc and sacsr have said thanks
#10 Bolens 1000 OFFLINE
  • 15,287 Thanks
  • 18,233 posts
Posted October 18, 2015 - 05:13 PM
Great find they are certainly different to drive at first with the engine in the rear.
I had a 430 a few years ago
The hand clutch is a neat feature and  believe they used the same transmissions as the walkbehinds.
#11 Cat385B ONLINE
    HAZMAT CAT
  • 14,261 Thanks
  • 10,108 posts
Posted October 18, 2015 - 05:20 PM
That's a great find right there. When I make my next Oklahoma tractor shopping tip, make sure to hide that one. :thumbs:
#12 KennyP ONLINE
  • 40,098 Thanks
  • 46,755 posts
Posted October 18, 2015 - 05:21 PM
It also has turning brakes! Has a brake pedal on each side! As far as the 3 controls by the seat, one is 1st or 2nd, middle is PTO, and the right one is Hi/Lo. Adjustable manual lift on the left and Fwd/Rev on the right side. Gas tank holds over 5 gallons and it's over the front axle. The grille shell is cast iron along with the front axle. And it's about twice the size of a GT axle.
  • Chris11, sacsr and Phluphy have said thanks
#13 KennyP ONLINE
  • 40,098 Thanks
  • 46,755 posts
Posted October 18, 2015 - 05:45 PM
I just checked Tractor Data & the shipping weight on this thing is 950 lbs. It's heavy!
  • Chris11 said thank you
#14 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted October 18, 2015 - 05:47 PM
Steering wheel is at the wrong end
  • Gtractor and KennyP have said thanks
#15 KC9KAS ONLINE
KC9KAS
  • 5,443 Thanks
  • 4,710 posts
Posted October 18, 2015 - 06:04 PM
Nice looking tractor.
I have often wondered about these rear engine Gravelys....is the front end light? Wheelies?
  • Chris11 and KennyP have said thanks
