300 with a no start
10 replies to this topic
#1 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted October 17, 2015 - 05:20 PM
I cleaned the carb today put it back on an it won't fire I have good spark. The battery also goes dead after cranking in a very short time
#2 Trav1s ONLINE
Trav1s
  • 3,521 Thanks
  • 4,498 posts
Posted October 17, 2015 - 06:28 PM
Will it fire if you spray carb cleaner in the carb?  Sounds like the float is not letting in enough fuel
#3 propane1 ONLINE
propane1
  • 9,156 Thanks
  • 4,284 posts
Posted October 17, 2015 - 07:35 PM
First , a new battery maybe. Adjust your carb settings. Did it run ok before the carb cleaning. Noel.
#4 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted October 17, 2015 - 07:44 PM
It ran alright that's why I cleaned the carb. When I took it apart there was a spring in the bowl I'm guessing to help the float maybe?? Or is that spring the problem, I'll be taking it back off tomorrow after work I'm guessing.
#5 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted October 17, 2015 - 07:45 PM
I don't have carb cleaner I just used a lol fresh gas to wipe the bowl out a clean the jets
#6 chieffan OFFLINE
  • 10,946 Thanks
  • 6,941 posts
Posted October 17, 2015 - 07:51 PM
If it ain't broke, don't fix it.  Depending on the shape of the spring, if it is a fine tight coil with two legs on each end it is probably the main seat spring.  Supposed to go over the pin that holds the float to the casting.
#7 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted October 17, 2015 - 08:03 PM
It's a lose lightweight spring that rested on the bottom of the bowl an bottom of the float. I had to have the choke slightly on an no less the quarter throttle or it would stall out.
#8 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted October 18, 2015 - 05:42 AM
Is the plug wet or dry after cranking? Do you have a good strong spark? Spark should be blue and snappy. If not, check the points. Both my Kohlers have the kohler carbs with the spring up on the float pivot. No spring from the float to the bottom of the bowl. If your battery voltage is low that will make it hard to get started for sure.
#9 Trav1s ONLINE
Trav1s
  • 3,521 Thanks
  • 4,498 posts
Posted October 18, 2015 - 05:54 AM
What carb is it? If you say walbro, I am afraid I will start on a rant that will not be pretty...
#10 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted October 18, 2015 - 08:12 AM
its a factory carb an since im at work right now i checked the rebuild kits i have the carter carb
#11 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted October 20, 2015 - 08:50 PM
Well it's alive tonight an running with no choke at all after its it's running an will restart with out having to use the choke
  • propane1 said thank you
