Adding a three point to an eaton rear end
4 replies to this topic
#1 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted April 15, 2011 - 11:22 PM
I have a 92 model Lawnboy YT 14 H with a bad deck and no luck finding one. I was thinking of adding a homemade cat 0 three point to it to make it a somewhat useful tractor. I know it probably is not tough enough to do any serious work but would be nice to have a use for it other than just pulling a trailer. It has an Eaton 850 trans axle. I was wondering if it was possible to tap into this rear end to power a lift and if you can, does anybody have any drawings or can you walk me through the process.
#2 IamSherwood OFFLINE
  • 8,395 Thanks
Posted April 16, 2011 - 07:18 AM
Can't help you on the Eaton trans axle, as I'm not familiar with them.
In the manuals section-Tractors and Implements-Massey Ferguson-Implements
I posted a pdf of Cat 0 specs.
#3 olcowhand OFFLINE
  • 42,896 Thanks
  • 31,939 posts
Posted April 16, 2011 - 07:30 AM
If it doesn't have hydraulic deck lift, then the pump won't be ported & you can't power hydraulics off it.
#4 Alc ONLINE
  • 7,226 Thanks
  • 7,578 posts
Posted April 16, 2011 - 07:36 AM
Did your tractor have a manual lift for the deck ? Maybe you could adapt a rod or bar to raise and lower the 3pt .
#5 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted April 16, 2011 - 08:32 AM
Ok yeah it had a manual deck. I didn't know but I was hoping that I could just tie into the lines that run to the filter. But I guess they probably are not pressurized high enough to do any lifting. Ah well I was just throwing it out there. I guess since I am not going to use the deck I could always just run a power steering pump off the electric clutch and run the 3 point off of that. Hmmmm...
