review on charging
3 replies to this topic
#1 holdenboy1960 OFFLINE
  • 1,749 Thanks
  • 941 posts
Posted October 17, 2015 - 05:56 AM
Curious on what ya'll think is better magneto charging or generator charging on GT's,
plz express your thoughts as well ty
magneto                                                            generator
column (1) ......................................................column (2 )
Edited by holdenboy1960, October 17, 2015 - 05:57 AM.
#2 boyscout862 ONLINE
  • 13,231 Thanks
  • 9,292 posts
Posted October 17, 2015 - 06:16 AM
As long as its working, I don't have a preference. Good Luck, Rick
  • WNYTractorTinkerer, Genem and holdenboy1960 have said thanks
#3 jd.rasentrac OFFLINE
  • 4,783 Thanks
  • 4,277 posts
Posted October 17, 2015 - 08:47 AM
:iagree:  it doesn't matter how it works, it's only important that it works. It's just a GT, no spaceshuttle...
#4 dodge trucker ONLINE
dodge trucker
  • 2,536 Thanks
  • 3,215 posts
Posted October 17, 2015 - 09:44 AM
Back when starer/generators were more common, those generators did not produce much juice. Many flywheel magnetos put out about what those would have.  Main advantage a stator under the flywheel has is that there is no starter/gen to take up what may be valuable space where the engine would mount, and 1 less belt to worry about. Both setups would rob about the same amount of HP from the engine while producing a given level of power. but a starter/gen can usually be removed for service easier, where a stator under the flywheel might require you to yank the engine to be able to pull the flywheel if it were to go bad.
  • lrhredjb, boyscout862, HANKG and 1 other said thanks
