Wanted
Shroud for Wisconsin AH
9 replies to this topic
#1 DougT ONLINE
DougT
    Dog Approved
  • 6,045 Thanks
  • 4,449 posts
Posted October 14, 2015 - 01:51 PM
I'm looking for a shroud and all related tin work for a Wisconsin AH. This is the squared off shroud and not the rounded style like the AHH
#2 Bolens 1000 ONLINE
  • 13,248 Thanks
  • 17,420 posts
Posted October 14, 2015 - 03:41 PM
let me see what I can dig up for you.....
Do you have the serial by chance?
#3 DougT ONLINE
DougT
    Dog Approved
  • 6,045 Thanks
  • 4,449 posts
Posted October 14, 2015 - 06:09 PM
It didn't come with a tag either. Did they stamp the number anywhere else? The engine would be from the mid 30's..
#4 Bolens 1000 ONLINE
  • 13,248 Thanks
  • 17,420 posts
Posted October 14, 2015 - 06:19 PM
Couple different types were used depending on serial, I'll try and see what the differences were
  • DougT said thank you
#5 DougT ONLINE
DougT
    Dog Approved
  • 6,045 Thanks
  • 4,449 posts
Posted October 15, 2015 - 07:28 AM
What was the serial break? Maybe I can figure it from there. I've only seen 2 styles. The earlier one with the squared front edge and the later one with the rounded front edge.
#6 Bolens 1000 ONLINE
  • 13,248 Thanks
  • 17,420 posts
Posted October 15, 2015 - 09:39 AM
Hmm... no luck on any of my Wisconsin sources
best i can do is one of the rounded shrouds from an AHH , new but expensive $ 196.00
#7 Tbrooks ONLINE
Tbrooks
  • 433 Thanks
  • 297 posts
Posted October 16, 2015 - 07:07 PM
Do you need the rounded or square cornered shroud?
#8 DougT ONLINE
DougT
    Dog Approved
  • 6,045 Thanks
  • 4,449 posts
Posted October 17, 2015 - 10:05 PM
The square cornered one.
#9 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,465 Thanks
  • 2,805 posts
Posted October 18, 2015 - 09:15 AM
are there any pictures showing this round/squared look??
#10 DougT ONLINE
DougT
    Dog Approved
  • 6,045 Thanks
  • 4,449 posts
Posted October 20, 2015 - 06:25 AM
This is an AEH with the rounded shroud. the front panel of the shroud is stamped and the seam is at the back. the edges of the shroud are rounded from the stamping. The cover over the head is just a small square that is fairly flat.
I believe that this emgine is an AE but i've never pulled the head and measured the bore and the tag is missing. At any rate, it has the early square corner tin. The main body is actually made of 3 pieces and spot welded together. The cover over the head is also the front top curve. Hope this helps show the difference.
  • Lauber1 said thank you
