Making SS Exhaust Flanges
17 replies to this topic
#1 tiretrx OFFLINE
tiretrx
  • 2,273 Thanks
  • 1,227 posts
Posted October 14, 2015 - 12:06 PM
On my last build I fabbed up the pipes and flanges out off stainless.
The pipes were just cut and welded so that was real straight forward. The flanges were rough cut, drilled, ground and finish ground by hand. Not a biggie, but knowing this wasn't the first time I did it and wouldn't be the last made me wish there was an easier way. My solution was building a fixture that I could use on my CNC's.
Used 3/16" thick 316SS for it's corrosion resistence and welding attributes.
20150915_144327_zpsbmurx7cg.jpg?14423449
Clamped it up and drilled outside bolting holes to final size. Exhaust hole was left small so that it could be milled to final size.
20150915_150602_zpsitqzfvow.jpg?14423449
Took the drilled blank, and built a fixture. Here it is in the vise with the blank bolted down.
20151014_112329_zpsetivxk5d.jpg?14448402
A little programming on the big Mazak mill.
20151014_090531_zpsd2dvnnj0.jpg?14448402
20151014_090514_zpskdalmfpn.jpg?14448402
Chips away!
20151014_113337_zpsd6vgotur.jpg?14448402
20151014_114635_zpshqz5pdvr.jpg?14448402
Viola.
20151014_114939_zpslwj8slat.jpg?14448402
  • olcowhand, limebuzz, Bruce Dorsi and 7 others have said thanks
#2 chieffan OFFLINE
  • 11,377 Thanks
  • 7,120 posts
Posted October 14, 2015 - 12:56 PM
Easy when you have the tools to work with.  Hi end equipment for working of a Gt in my book.
  • tiretrx and karel have said thanks
#3 dthomp17 ONLINE
dthomp17
  • 605 Thanks
  • 482 posts
Posted October 14, 2015 - 01:00 PM
Nice job, looks very professional. Wish I had that kind of equipment to work with.
#4 tiretrx OFFLINE
tiretrx
  • 2,273 Thanks
  • 1,227 posts
Posted October 14, 2015 - 01:11 PM
Thanks! CNC's are very productive machines. The problem being they only do what they are told, or are programmed, to do. Feeds, speeds, tool paths and the tools used are all determined by the machinist. Plotting a shape is relatively easy, the rest requires some working experience. Fortunately, I have them at my work, so I get to use them on my projects :thumbs:
  • olcowhand and KennyP have said thanks
#5 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted October 14, 2015 - 01:20 PM
If ya got em, use em!  :thumbs:
  • KennyP and tiretrx have said thanks
#6 Cat385B OFFLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,141 posts
Posted October 14, 2015 - 02:26 PM
Nothing but cheating, if ya axe me.
  • tiretrx and petrj6 have said thanks
#7 tiretrx OFFLINE
tiretrx
  • 2,273 Thanks
  • 1,227 posts
Posted October 14, 2015 - 02:51 PM
Like a GPS on a combine, dude.
#8 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted October 14, 2015 - 02:53 PM
   I agree with cat, that's cheating !!!! I can do that sort off work in my garage with a drill press and belt sander.  just got to watch your fingers :thumbs:
  • tiretrx said thank you
#9 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted October 14, 2015 - 03:12 PM
   they have cnc machines like that where I work and I have been trying to convince the operator to make me some plaques for my gt-s but he has not been to receptive,  kind of stuck up like that.  only solution I can see is to learn to run it myself :D
  • limebuzz and tiretrx have said thanks
#10 Cat385B OFFLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,141 posts
Posted October 14, 2015 - 03:47 PM
Oops. Yeah, I should of turned the Trimble off in the D6 before I posted that.
  • olcowhand and tiretrx have said thanks
#11 Canawler OFFLINE
Canawler
  • 1,951 Thanks
  • 1,806 posts
Posted October 15, 2015 - 12:48 PM
Very nice.
So now that you can mass produce them, I'm guessing your selling price will drop?
Hint, hint...
#12 tiretrx OFFLINE
tiretrx
  • 2,273 Thanks
  • 1,227 posts
Posted October 15, 2015 - 01:01 PM
Very nice.
Hint, hint...
Absolutely! I was explaining to one of the operators yesterday that the 1st one on CNC might take 6-8 hours to make. Building the fixtures, writing programs, troubleshooting. You could make perhaps 10 by hand using a drill press, band saw and a grinder in that time(I've done it). But every ensuing one on the CNC takes less than 2 minutes, complete. Hour after hour, day after day. I did something similar for Gravely PTO covers, and they actually turned into a consistent seller.
  • limebuzz said thank you
#13 limebuzz OFFLINE
limebuzz
  • 1,063 Thanks
  • 1,010 posts
Posted October 16, 2015 - 06:49 PM
Nice work. Looks great
#14 tiretrx OFFLINE
tiretrx
  • 2,273 Thanks
  • 1,227 posts
Posted October 21, 2015 - 01:00 PM
Used a flange for the 1st time on a header project for a friend today. He has a Gravely Pro 12 walk behind.
First, we had to make the end adapter for the the muffler flange.
20151020_130633_zpshjty4k0b.jpg?14454479
20151020_140008_zpsvqccunmi.jpg?14454479
20151020_141558_zpspw8j8lhd.jpg?14454479
Couple angle cuts and just tacked up right now for my friend to dry fit.
20151021_131023_zpssjtyrenh.jpg?14454479
Also of note. The NY Mets are one game away from the World Series.............
  • olcowhand and Cvans have said thanks
#15 mrmd OFFLINE
mrmd
  • 281 Thanks
  • 138 posts
Posted October 21, 2015 - 06:47 PM
This was a very interesting topic until you posted that last picture.
  • tiretrx and devans have said thanks
