In A Quandary
11 replies to this topic
  • 2,294 Thanks
  • 1,477 posts
Posted October 14, 2015 - 10:35 AM
I mentioned in another thread that I am reviving an old sickle mower.  My current problem is that I need 13 sickle sections, and I have a couple of options, none of them perfect.
Option 1: I could buy new ones, but the last time I did that, it was almost $150 dollars and they wouldn't even talk me as a Canadian.  I had to get an American to place the order and then ship them to me.
Option 2: I could make new ones, but that means buying some hardenable steel and spending a lot of time.
Option 3: I could rob them off of my working spare Simplicity mower, but that makes that mower useless.
Option 4: I could rob them off of my spare Allis mower bar, but then I don't have a spare.
What would you do?
  • Lauber1 said thank you
#2 oldedeeres ONLINE
oldedeeres
  • 7,065 Thanks
  • 3,662 posts
Posted October 14, 2015 - 10:53 AM
Don't know what your work area is like--- heated and plenty of light?  My Olde Deere would take option #2 in a heart beat. It's coming to winter and some time should free up, short of moving snow, seat time is limited, and he'd have enjoyed the challenge. Around here, options #3 & #4  just meant that once robbed, always robbed,    :smilewink: .
  • New.Canadian.DB.Owner and propane1 have said thanks
#3 chieffan ONLINE
  • 7,279 Thanks
  • 5,147 posts
Posted October 14, 2015 - 11:09 AM
I agree.  I did the same thing only with about 4 sections.  Some times it is easier to re-drill the bar to match the sections.  Then weld the old bar holes shut.  Your committed to the remakes but as long as they are available at a decent price?   If your restoring the mower, that is another story and leaves only one option.
  • New.Canadian.DB.Owner and JBRamsey have said thanks
#4 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted October 14, 2015 - 12:39 PM
Can you find sections locally that are close to fitting? Drilling the bar and filling holes would not be a big deal.
If too wide a belt grinder would narrow them pretty quickly?
The ones I see in the farm supply store are pretty universal .
Though I. Have not done this since I was a teenager.
Edited by JD DANNELS, October 14, 2015 - 12:40 PM.
#5 LilysDad ONLINE
LilysDad
    --Crazy about GTTalk-- 'sort of'
  • 10,980 Thanks
  • 8,389 posts
Posted October 14, 2015 - 12:41 PM
#1 You could marry an American.
#2 Would saw blade steel work?
  • Lauber1, New.Canadian.DB.Owner and Bill 76 have said thanks
#6 propane1 ONLINE
propane1
  • 7,107 Thanks
  • 3,569 posts
Posted October 14, 2015 - 02:05 PM
# 2 would be my pick.    Noel
  • New.Canadian.DB.Owner and Bill 76 have said thanks
#7 boyscout862 OFFLINE
  • 10,784 Thanks
  • 8,078 posts
Posted October 14, 2015 - 02:23 PM
Maybe the best decision is to wait a bit. I came across a section of sickle that have teeth very close to the size I need to repair my Simplicity bar. It was $1. Look around and you will probably find what you need without having to canabalize something you prefer to leave intact. Good Luck, Rick
#8 Alc ONLINE
  • 5,995 Thanks
  • 6,918 posts
Posted October 14, 2015 - 06:27 PM
If  you list the size your looking for I will keep at eye for them at our fall tractor show this weekend at Jacktown Pa
  • Lauber1 and New.Canadian.DB.Owner have said thanks
#9 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,471 Thanks
  • 2,811 posts
Posted October 14, 2015 - 07:06 PM
yes give us the size of  the old section, them things are universial, there has to be others around, just not at your house.
#10 MH81 ONLINE
  • 28,882 Thanks
  • 29,265 posts
Posted October 14, 2015 - 08:23 PM
What would you do?
I am cheap. Option 5 (about 1/2 way thru this post)
http://gardentractor...20/#entry314232
  • olcowhand, Alc, KennyP and 1 other said thanks
#11 Jazz ONLINE
Jazz
  • 1,755 Thanks
  • 1,114 posts
Posted October 17, 2015 - 04:42 PM
If a seller does not ship international (which is likely the issue) find a shipping depot in Buffalo that you can ship goods to. They do exist solely for Canadian customers..There are two such businesses at our local border crossing...They charge $3.00 per parcel ,,a bit more if a forklift is required. When our dollar was strong the depot I use was handling up to 5000 packages a week for us locals.
  • limebuzz, Alc and New.Canadian.DB.Owner have said thanks
#12 nbent ONLINE
nbent
    customizer
  • 648 Thanks
  • 526 posts
Posted October 18, 2015 - 09:31 AM
Post some dimensions I will look through what I found in the shop here plus a friend has a couple old sickle bars in the attic of his barn
