Check your brakes
6 replies to this topic
#1 nbent OFFLINE
nbent
    customizer
  • 651 Thanks
  • 530 posts
Posted October 12, 2015 - 09:13 PM
uploadfromtaptalk1444701995088.jpg this is the drivers side front rotor off of my 85 Chevy truck. I bought it earlier this year and did a full service and inspection of the truck when I got it. I blew the head gaskets on it after a heater hose blew. A few days ago I finished putting the new heads and turbo setup on I took it for a drive and as I was pulling back in the driveway I hit the brakes a little harder than normal to avoid hitting the dog and that's when this rotor let go. So I took it off and changed both front rotors and the caliper on the drivers side as it had a crack where the lower pin goes through.
  • Gtractor, Alc, wvbuzzmaster and 3 others have said thanks
#2 wvbuzzmaster OFFLINE
  • 4,714 Thanks
Posted October 12, 2015 - 09:18 PM
Why is there only a small amount of metal holding that on there. What do the slots it broke off of have to fit around??
  • nbent said thank you
#3 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted October 12, 2015 - 09:40 PM
Stuff like this is happening more and more. Combo of making it cheaper and lighter coupled with overseas qc.
Glad you weren't hurt.
  • wvbuzzmaster, nbent and boyscout862 have said thanks
#4 nbent OFFLINE
nbent
    customizer
  • 651 Thanks
  • 530 posts
Posted October 13, 2015 - 12:06 AM
The wheel studs wouldn't fit with out the holes older ones were solid but they won't fit this truck
  • Traill95 said thank you
#5 JDBrian OFFLINE
  • 9,599 Thanks
Posted October 13, 2015 - 04:39 AM
That's pretty scary. Hopefully the dog survived the incident and nobody got hurt. Could have been much worse!
#6 cpg OFFLINE
cpg
  • 250 Thanks
  • 151 posts
Posted October 13, 2015 - 12:30 PM
Is it just the way the camera picked it up or did you have a stuck caliper? The ring around the braking surface looks blue and scorched like it got really hot.
#7 nbent OFFLINE
nbent
    customizer
  • 651 Thanks
  • 530 posts
Posted October 13, 2015 - 12:40 PM
The dog lived thankfully. Yes it is blue its from the caliper being worn and not being straight
