Wanted
Wheel weights
13 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 12, 2015 - 06:41 PM
Looking for any brand of wheel weight approximately 50-60 pounds each. Orphan weights of any weight are welcome.
#2 MH81 OFFLINE
Posted October 12, 2015 - 07:00 PM
You've got to be kidding... I know you've got a set of Bolens weights without a tractor...
Just kidding, what are you planning on weighting down Casey?
  • wvbuzzmaster said thank you
#3 farmerall OFFLINE
farmerall
  • 2,204 Thanks
  • 1,474 posts
Posted October 12, 2015 - 07:32 PM
I got two concrete filled plastic weights that need a new home. You pick them up and they are yours.
#4 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted October 12, 2015 - 07:48 PM
   I have a few 12" steel burnout out back I use for wheel weights.  they weigh about 30lbs each if I remember, got to be three or four sets out there.  shipping will be the trouble.  if you want them pm me and we can talk money.
                                   Pete
#5 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 12, 2015 - 08:47 PM
Cub Cadet 108, New Holland, etc...
#6 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 12, 2015 - 08:50 PM
Not a fan of the plastic concrete weights, but appreciate the offer, and might take the detour sometime, but not sure, so if anyone wants them before me, don't hold on to them.
#7 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 12, 2015 - 08:53 PM
                                   Pete
Pete, what do these look like? Will they nest inside of a 12" wheel, or just ride on top? I really prefer weights that don't stick past the tire more than 1/2". I about tore weights off a tractor that had them sticking out 1-1/2" past, and or the sides of the trailer I was loading it onto.
#8 MH81 OFFLINE
Posted October 12, 2015 - 09:06 PM
Aka bad driving...
#9 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 12, 2015 - 09:14 PM
Aka bad driving...
No... it is 45" between the sides of the trailer, and the tractors overall width is 42" outside to outside of the tires. The wheel weights add 3 inches to the overall width... Does anyone see a problem with the measurement? Lol
Edited by wvbuzzmaster, October 12, 2015 - 09:14 PM.
#10 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted October 12, 2015 - 09:18 PM
What is a inch???
In Canada distance is measured in km or cm.
  • limebuzz, MH81 and wvbuzzmaster have said thanks
#11 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 12, 2015 - 09:19 PM
What is a inch???
Your wheel weight is only measurable in km... Lol
#12 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted October 13, 2015 - 04:40 AM
   they are steel burnouts 1" thick and they set just inside the rim on the beadlock surface.  no they don't nest down into the rim.  if you put one on it will stick out about 1/2" past the rim plus the hardware to hold them on, probably now what you are looking for if you have clearance issues.
                                       Pete
Edited by petrj6, October 13, 2015 - 04:40 AM.
#13 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 13, 2015 - 11:06 AM
Only reason clearance is an issue to me is that i dont have endless space or turning room at times. Thanks Pete.
#14 burned300 OFFLINE
burned300
  • 12 Thanks
  • 8 posts
Posted October 14, 2015 - 10:16 AM
I'm in Columbus, Ohio w/orphaned 50 lb John Deere cast weight
