1941 National Mower Co. heavy duty sickle mower.
7 replies to this topic
#1 classic ONLINE
classic
  • 5,709 Thanks
  • 2,391 posts
Posted October 11, 2015 - 11:56 AM
I picked up this odd looking sickle mower and had a hard time finding info out about it. I'm guessing it was made in 1941, since that's what the Briggs model A dates back to. The engine starts right up and runs fine, the sickle engages and functions fine, but I have to do some work on the drive engagement clutch. I did find a brochure on the machine, but I was wondering if anyone has a pic of the drive clutch assembly.
Edited by classic, October 11, 2015 - 12:00 PM.
  • Bolens 1000, earthgrinder, DougT and 14 others have said thanks
#2 classic ONLINE
classic
  • 5,709 Thanks
  • 2,391 posts
Posted October 11, 2015 - 02:58 PM
Well, I just figured out what was wrong with the clutch. Somebody tinkered with it and had the fingers way out of adjustment. The clutch engages and disengage fine now. I had another old Firestone Power Tread tire laying around, so I swapped out the bad tire. Those split rims are a nightmare! Anyway, I took it over to some tall grass and gave it a try. The old machine works fine, but I'll have to sharpen the cutter bar and replace one broken rock guard.
  • earthgrinder, Gtractor, MH81 and 6 others have said thanks
#3 propane1 ONLINE
propane1
  • 9,754 Thanks
  • 4,521 posts
Posted October 11, 2015 - 05:39 PM
That's neat. Noel.
  • classic said thank you
#4 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted October 11, 2015 - 08:42 PM
very cool looking machine.
#5 MH81 OFFLINE
  • 29,979 Thanks
Posted October 11, 2015 - 09:48 PM
Awesome piece you saved.
Reminds me of something, just can't place it yet.
#6 classic ONLINE
classic
  • 5,709 Thanks
  • 2,391 posts
Posted October 11, 2015 - 11:01 PM
I did find a post here by member DB1 regarding one of these sickle mowers. It was on page 6 of the "walk behind of the day" thread. Here are the pics of DB1'S mower.
  • Bolens 1000, Alc and KennyP have said thanks
#7 Rustysteele OFFLINE
Rustysteele
  • 301 Thanks
  • 93 posts
Posted October 22, 2015 - 04:20 PM
DSCN2562.JPG I`ve seen 3 of those larger National mowers here in New England, for some reason they aren`t too rare around here. Here`s a picture of their small mower that I was lucky enough to find at a flea market this past summer, it is from the 1940`s and has a Briggs Model N on it. I`ve used it, but the teeth need to be sharpened, plus the tall weeds get tangled up in the cutter drive mechanism. But I like it anyway!
  • Alc, DB1 and classic have said thanks
#8 classic ONLINE
classic
  • 5,709 Thanks
  • 2,391 posts
Posted October 22, 2015 - 08:17 PM
Rustysteele, the smaller one like yours would probably be more useful to me. I did use mine for a bit and it worked good, but it needs some tinkering with. I found a new cutter bar with the same teeth that's new and has been laying on a shelf for years. The owner doesn't know what it fits, so he said that I can have it for cheap. I plan on restoring my sickle mower and use it around the place once in a while. I like the looks of the thing, and I'm a fan of those old hand crank Briggs engines. It fires right up cold, with one or two cranks. The mower is bigger than I thought, and it weighs 260 lbs. according to the pamphlet. The owners father would use it to cut some hay for his horse once in a while, years ago.
National did make a wire grass/weed guard that stood above the cutter bar and would push the weeds forward and away from the cutter bar. There is a pic of the guard in the pamphlet. I see that there are 4 holes in your sickle bar, two at each end. You could fab up a grass guard to keep the grass and weeds away from the bar and shaft assembly.
Edited by classic, October 22, 2015 - 08:25 PM.
  • Alc, DB1 and Rustysteele have said thanks
