My 300 aka Tank
24 replies to this topic
#16 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted December 04, 2015 - 08:46 AM
Here's the loaded ags an weights ready for snow
#17 Oldford OFFLINE
Oldford
  • 1,134 Thanks
  • 786 posts
Posted December 04, 2015 - 04:49 PM
Yea i can have the tiller an plow on they work off different hydraulic levers here's a pic after I got done in the garden
Does the tiller go up any higher, with a jack or ratchet strap?  looking at a tiller but don't want it hanging up on plow banks. i have the same tractor as you btw
#18 Oldford OFFLINE
Oldford
  • 1,134 Thanks
  • 786 posts
Posted December 04, 2015 - 04:53 PM
Thanks the 42" was not enough since the rear tires stuck past the blade an the really would have now that I have the ags on it now the off set is a little different then stock jd but not by much
My rims are offset can flip them around to change the stance, maybe yours are too...?
  • Trav1s said thank you
#19 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted December 04, 2015 - 05:23 PM
Yes till goes up higher for some reason the ram the lifts it can't hold the weight an it slowly drops on the lift bar the bracket will rotate down to lock the tiller up. Mine is currently set in the most aggressive setting for the first few times so i can get the rocks worked up an picked out same with roots from the old shrubs.
I can flip my rims but they'll stick out farther then they already do. So I'll deal with them this way, an the 300 plow was a factory 54" the p.o. adapted a 200 series with hydrolics to work on the 300. Which he did a great job doing an it works great he used a deck lift ram to raise an lower the blade.
  • Oldford said thank you
#20 Trav1s ONLINE
Trav1s
  • 3,168 Thanks
  • 4,283 posts
Posted December 04, 2015 - 08:13 PM
A set of 23x8.50-12's (used on the 312s and some 120s) on the back would give a narrower track than the 23x10.50-12s that came on the 300s
Edited by Trav1s, December 04, 2015 - 08:14 PM.
  • backwoods said thank you
#21 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted December 04, 2015 - 08:46 PM
True I like the width of the 10.50's when I plow across the yard the cub has 6-12's an it made a mess of the yard last winter when it was wet snow
#22 Trav1s ONLINE
Trav1s
  • 3,168 Thanks
  • 4,283 posts
Posted December 04, 2015 - 10:33 PM
I like the 23x8.50-12s as they put more weight on a smaller surface area.
#23 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted December 18, 2015 - 09:39 PM
Well since it's still unseasonably warm in my neck of the woods an I've been itching to plow something I loosened some dirt an filled in the low spot just off the blacktop. This will also help keep water out of the garage when it rains.
uploadfromtaptalk1450492639540.jpg uploadfromtaptalk1450492655100.jpg uploadfromtaptalk1450492670799.jpg
  • KennyP and Oldford have said thanks
#24 MH81 OFFLINE
Posted December 19, 2015 - 07:33 AM
I missed this.
Great trade, sounds like everyone was happy.
Good looking tractor and Avery looks like its fun to operate too.
#25 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted December 19, 2015 - 08:01 AM
Oh yea Avery loves this one come spring I'll start working on hers until then I can share she might even help plow snow if we ever get enough to push.
