Help identify
mtd tractor forum
13 replies to this topic
#1 CarlD OFFLINE
CarlD
  • 4 Thanks
  • 9 posts
Posted October 10, 2015 - 05:35 PM
Western Auto; IMG_20150802_164346007.jpg Serial # 41-005-3235, Model LT 7CE _ _
#2 olcowhand ONLINE
  • 41,262 Thanks
  • 31,447 posts
Posted October 10, 2015 - 05:49 PM
Looks like an MTD 990 to me.
  • boyscout862, Dieselcubmike and CarlD have said thanks
#3 Rock farmer OFFLINE
Rock farmer
  • 1,198 Thanks
  • 1,234 posts
Posted October 10, 2015 - 05:56 PM
Looks like an early MTD 990 me.
It's been re-powered.
What's the Question?
Thinking of buying?
Joe
  • CarlD said thank you
#4 CarlD OFFLINE
CarlD
  • 4 Thanks
  • 9 posts
Posted October 10, 2015 - 06:21 PM
Would like to find manual for it. Trying to go by serial number with luck & partial serial number doesn't help
#5 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,010 Thanks
  • 4,418 posts
Posted October 10, 2015 - 06:27 PM
I want!
#6 boyscout862 OFFLINE
  • 12,864 Thanks
  • 9,176 posts
Posted October 10, 2015 - 07:45 PM
Try this  as a starting point   http://gardentractor...guide-770-0851/   Since I can't see the front grill there are a bunch of possibilities. Most are basically the same. The engine manual is in our Manuals Section. Good Luck, Rick
  • Gtractor and CarlD have said thanks
#7 CarlD OFFLINE
CarlD
  • 4 Thanks
  • 9 posts
Posted October 10, 2015 - 09:29 PM
Thanks everyone, will give the manual a read Thanks Rick
#8 VTXrider OFFLINE
VTXrider
  • 517 Thanks
  • 376 posts
Posted October 11, 2015 - 06:14 AM
Seeing that it has a winch lift in front for the plow blade. The front wheel spindles are replaced with trailer hubs. Looks like the 3 point arms are used only for towing the mower but no lift. The PTO would no longer function. Designed for plowing and mowing a large area only. Nice conversion for an old workhorse.
Edited by VTXrider, October 11, 2015 - 06:18 AM.
#9 CarlD OFFLINE
CarlD
  • 4 Thanks
  • 9 posts
Posted October 11, 2015 - 06:34 AM
3 pt hitch does work, have plow, middle buster, rock rack, culivator( all home made). previous owner installed newer BS 16hp and done away with PTO( :wallbanging:). I modified blade from 4 wheeler blade & add winch for lifting. will try to ad pic's of equipment. Will be looking at installing hyd's
  • Rock farmer said thank you
#10 Diesel1050 OFFLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted October 11, 2015 - 09:49 AM
It has ags!
#11 VTXrider OFFLINE
VTXrider
  • 517 Thanks
  • 376 posts
Posted October 11, 2015 - 10:32 AM
Welcome to the forum Carl. So you already own it and want to modify it already? I hope it is not contagious! :D
The mid PTO is used mostly for the mower deck or tiller so maybe a powered tiller is in the future.
I would like to see how the new engine is mounted. More pictures all the way around if you don't mind.
Can a hydraulic pump mount to the front of the engine?
Can you tell what you gave for your MTD 990 package?
#12 CarlD OFFLINE
CarlD
  • 4 Thanks
  • 9 posts
Posted October 11, 2015 - 11:23 AM
Ya its contagious,IMG_20151011_110841039.jpg still biulding this one, IMG_20151011_110903816.jpg IMG_20151011_110933559.jpg
  • VTXrider said thank you
#13 CarlD OFFLINE
CarlD
  • 4 Thanks
  • 9 posts
Posted October 11, 2015 - 11:25 AM
Will post more pics of 990 when I get out to cabin next time
#14 CarlD OFFLINE
CarlD
  • 4 Thanks
  • 9 posts
Posted October 11, 2015 - 11:27 AM
I gave $1000. for tractor, plow, middle buster, smaller scarifier.
