Introducing Alice!
allis chalmers ac 718h modified
148 replies to this topic
#76 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted January 26, 2016 - 12:07 PM
Not sure if drilling and taping is an option. I had to do that on a couple pulley allen set screws.
  • KennyP and holdenboy1960 have said thanks
#77 KennyP OFFLINE
  • 37,424 Thanks
  • 45,461 posts
Posted January 26, 2016 - 02:49 PM
Well, Keith was right again! A little heat from the Mapp gas torch and it came right out. :dancingbanana: Then, it was a matter of putting in the fitting and run the line.  I decided to pull the dash to put the gauge in. That's easier than pulling the fuel tank and battery on this. I cranked it over some before hooking the line in. Dummy me forgot the end at the engine wasn't hooked up! DOH! Nice puddle on the floor now, put some floor dry on it. Went ahead and put it all together. I put a compression union in the line at the back of the engine. I can unhook the line there if the engine has to come out.
Here's some pics. First is the gauge, check out the package. First tractor on there is an AC.
Here's the plug and fitting installed.
Fired it off! First pic is right after it started.
This is after about 5 minutes running at near full throttle. :dancingbanana: :dancingbanana:
And this is at idle after it warmed up! :dancingbanana: :dancingbanana: :dancingbanana:
I have 30W oil in it. I'll know more this summer  when the engine gets real warm, but I think this engine is in pretty good shape!
  • olcowhand, DH1, wvbuzzmaster and 6 others have said thanks
#78 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted January 26, 2016 - 03:38 PM
Nice oil pressure gauge.
Replace that ammeter with a volt gauge, you will like it a whole lot better. That's what I did on my Cub Cadet 108. Of course I spent $30 to get a gauge that matched the style of the tractor, and was made in USA.
  • KennyP and toppop52 have said thanks
#79 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted January 30, 2016 - 05:42 AM
very nice dash cluster & panel
#80 tractorskipper OFFLINE
tractorskipper
  • 397 Thanks
  • 273 posts
Posted January 31, 2016 - 10:08 PM
Cool dash!
#81 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted January 31, 2016 - 10:23 PM
Kenny, looks like we use the same PTO.
#82 toppop52 ONLINE
toppop52
  • 5,016 Thanks
  • 4,628 posts
Posted January 31, 2016 - 11:08 PM
I agree on both counts, nice work!
#83 KennyP OFFLINE
  • 37,424 Thanks
  • 45,461 posts
Posted February 01, 2016 - 05:33 AM
That's where my PTO came from! I had a couple of these from the 18 B&S laying about. Put one to work!
  • larrybl said thank you
#84 KennyP OFFLINE
  • 37,424 Thanks
  • 45,461 posts
Posted February 06, 2016 - 04:31 PM
Today, I ordered the rest of the decals, an Amp gauge (30-0-30), an the hourmeter. Alice will be happy!
  • larrybl and Texas Deere and Horse have said thanks
#85 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted February 06, 2016 - 05:03 PM
Would the place you get your decals from have any for a Craftsman II?
#86 KennyP OFFLINE
  • 37,424 Thanks
  • 45,461 posts
Posted February 06, 2016 - 05:12 PM
It's clickitandstickit! They have Sears, but older stuff. PM olcowhand about those!
#87 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted February 06, 2016 - 06:38 PM
PM sent. Thanks
#88 olcowhand ONLINE
  • 40,349 Thanks
  • 31,170 posts
Posted February 06, 2016 - 07:30 PM
I way prefer an ammeter over a voltage gauge.  You instantly can tell if things are charging as with a voltage gauge if not running a lot of DC power, you might run a while before a voltage gauge would show much of a drop.
  Kenny, Alice will really look great with those new stickies!
  • Texas Deere and Horse, KennyP and Newpaws493 have said thanks
#89 toppop52 ONLINE
toppop52
  • 5,016 Thanks
  • 4,628 posts
Posted February 06, 2016 - 09:17 PM
I'll respectfully disagree on the ammeter vs voltmeter, but that's a sweet tractor!
#90 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted February 06, 2016 - 09:51 PM
Kenny you machine is AWESOME, if someone else hasn't already told you. I have both the Voltmeter on Old Girl, and Amp meters on the Craftsman's. Both give information about the charging system, and both would be preferable over just a single gauge. Each has to be read differently, and you are probably already aware of these facts.
The AMP meter shows battery draw, and battery charge in Amps almost instantly. It does not show if the battery voltage is low (dead cell) or an over charging condition.
The VOLT meter gives an instant read on the battery voltage, If the voltage gradually climbs while running the battery is charging, if the battery voltage gradually falls while running it is being discharged. The Volt meter won't tell you instantly if charging or not.
  • KennyP and Newpaws493 have said thanks
Also tagged with one or more of these keywords: allis chalmers, ac 718h modified
