Wanted
wheel weights for case / Ingersoll 16 inch rim
4 replies to this topic
#1 jerseyhawg / glenn OFFLINE
jerseyhawg / glenn
  • 241 Thanks
  • 138 posts
Posted October 05, 2015 - 11:16 PM
Ok, I am getting close to getting my next tractor. A big wheel case or Ingersoll. I figured I better start searching for rear weights for the 16 inch wheel, rim. I understand the factory cast iron D 10 is the one to have, but I also am learning other cast weights will work to. Let me know what you have and want $. Pictures will be needed, and unless there close for pick up, shipping to 07748. Never knew wheel weight hunting would be such a chore. PM or email me. Thanks fellas.
Glenn
#2 jerseyhawg / glenn OFFLINE
jerseyhawg / glenn
  • 241 Thanks
  • 138 posts
Posted October 06, 2015 - 01:42 PM
JD 6600 combine weights will work I was told. I would just need the outer, not the interior rim weight. No clearance for it. Just throwing this info out there to improve my options.
Ok, seems these combine weight sre to heavy, 160lb a piece. Anyone have anything for a case Ingersoll rim?
Glenn
I guess the D 10 is the best so far. Open to ideas,,,,,,,,,,,,
Edited by jerseyhawg / glenn, October 08, 2015 - 04:21 PM.
#3 jerseyhawg / glenn OFFLINE
jerseyhawg / glenn
  • 241 Thanks
  • 138 posts
Posted October 08, 2015 - 11:57 PM
How about 103801 with a B stamped above them. 6 holes in the center. This is another set I found would work. They sit IN the center of the 16 inch rim, so they arent very large. About 55 lbs.
Glenn
#4 Rock farmer OFFLINE
Rock farmer
  • 1,318 Thanks
  • 1,282 posts
Posted October 14, 2015 - 06:02 PM
Youcan buy them new yu know.
#5 jerseyhawg / glenn OFFLINE
jerseyhawg / glenn
  • 241 Thanks
  • 138 posts
Posted October 26, 2015 - 03:55 PM
Bump
