My new Case 195
12 replies to this topic
#1 Matt O OFFLINE
Matt O
  • 119 Thanks
  • 98 posts
Posted October 05, 2015 - 06:28 PM
Hi everyone,
I recently aquired a case 195 tractor. At first glance it looks good but after a good look over I noticed my things that need to be addressed and have made a list of parts I need. I am in need of a left hand axle housing, the complete left hand disk brake assembly, disk brake pads both sides, brake rod from pedal to left brakes, cooling fan on the motor , and I may be forgetting something! I know it needs a new axle but I'm not even going to bother trying to find one, I'm going to have one made.
If anyone knows where I can get these parts please let me know. I plan to call steve from Ohio this week but just wondering if anyone has any ideas. Thank you
#2 Matt O OFFLINE
Matt O
  • 119 Thanks
  • 98 posts
Posted October 05, 2015 - 06:29 PM
Also, I noticed both disks are warped and far from straight, can I heat them up and straighten them out or will that damage them?
#3 Matt O OFFLINE
Matt O
  • 119 Thanks
  • 98 posts
Posted October 05, 2015 - 06:32 PM
Some picture of the disk, broken fan, and the broken axle housing
#4 Matt O OFFLINE
Matt O
  • 119 Thanks
  • 98 posts
Posted October 05, 2015 - 06:34 PM
Brakes and ID tag
#5 KennyP ONLINE
  • 37,391 Thanks
  • 45,446 posts
Posted October 05, 2015 - 07:05 PM
Looks like a nice project! Not a Case guru though.
  • Matt O said thank you
#6 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted October 05, 2015 - 07:44 PM
   Looks like you have your work cut out for you, parts look really close to a case 155.  exactly the same brake setup, I don't know about the brakes I would try tapping it with a hammer or wrench and listen to it, if it gives of a hi pitched ring than forget about heating it but if there is just a dull metallic clank then you may be able to heat it and straighten it without to much trouble.
                                       Pete
  • boyscout862 and Matt O have said thanks
#7 HANKG OFFLINE
HANKG
  • 6,196 Thanks
  • 3,381 posts
Posted October 05, 2015 - 09:08 PM
Hey Matt welcome aboard Steve Guider is the man for parts unless you can find a parts tractor his phone number is 937-363 3523
  • Matt O and jerseyhawg / glenn have said thanks
#8 jerseyhawg / glenn OFFLINE
jerseyhawg / glenn
  • 241 Thanks
  • 138 posts
Posted October 05, 2015 - 11:06 PM
Best of luck Matt, nice ride.
Glenn
#9 Matt O OFFLINE
Matt O
  • 119 Thanks
  • 98 posts
Posted October 06, 2015 - 04:01 AM
Thanks everyone, I will get in touch with Steve and will get back on here to let you know how it went.
#10 boyscout862 ONLINE
  • 12,518 Thanks
  • 9,028 posts
Posted October 06, 2015 - 07:22 AM
You might look at this http://newlondon.cra...5205750910.html . There is a swap meet this coming sunday at the Brooklyn, CT Fairgrounds. There is usually some GT stuff there. Later this month will be the huge auto Swap Meet at the Thompson Speedway. There is usually some GT things there too. Good Luck, Rick
#11 Matt O OFFLINE
Matt O
  • 119 Thanks
  • 98 posts
Posted October 07, 2015 - 07:24 AM
Thank you for the replies! Yesterday I took the cover off the rear end and noticed there are gears missing. I need all the small gears and pins that mount inside off a housing thats part of a larger gear that connects to the left axle. Anyone know where I might find these? Or anyone have measurements so I can have them made? Oh, and I forgot to add I need a rear hitch!!!
Thanks, matt
#12 1031d OFFLINE
1031d
  • 32 Thanks
  • 90 posts
Posted November 22, 2015 - 12:50 AM
Odd your missing those gears in there as it's useless without!  You can use the internals of a 155 rear end except for the axles but the axle housings and brakes are the same.  If Steve doesn't have all you need try Barneveld Imp 1-608-220-7062  He and Steve are good friends and I sold him a couple 155 parts tractors over the years.  He is also a CCI dealer and has many new parts in stock like that fan.  I have a 1968 195 and have rebuilt the whole thing after I got tired of the piston slap and broke a shaft in the rear end.
2013-02-02_11-40-59_628_zps9d9fa03c.jpg2013-02-03_15-13-43_459_zps2d7c4359.jpg2013-03-06_09-21-33_782_zps837d6627.jpg
#13 Potsie33 OFFLINE
Potsie33
  • 4 Thanks
  • 8 posts
Posted December 03, 2015 - 08:42 PM
Nice looking 195! Good luck on the repairs
