Sickle Mower - Missing Part - Help Needed
17 replies to this topic
  • 2,347 Thanks
  • 1,502 posts
Posted October 05, 2015 - 01:43 PM
I have an old sickle mower I am trying to get back up and running.  It was missing the knife bar, and the piece that attaches the bar to the drive arm.  It looks like it should be an L bracket with a 1" ball attached to it.  I am hoping someone recognizes the set up and maybe has a picture and or some details.  The missing piece is # 58 on the manual page, and the drive arm is #18.  The knife bar in the photos is my spare from my Allis HB112.  I think the missing knife bar would have a blank space at the end where the L bracket would attach.
IMG_20150710_135351.jpg missing link.jpg missing link 2.jpg hole.jpg hole 2.jpg manual.jpg
#2 Talntedmrgreen OFFLINE
  • 3,279 Thanks
  • 2,311 posts
Posted October 05, 2015 - 02:11 PM
Very interesting sickle!  What type/model is that?  The rockgaurds and bar hold-downs look just like a Simplicity bar, but absolutely nothing else does.  The knives are the right size too, and I was of the impression only Simplicity and Jari used those small knives?
#3 New.Canadian.DB.Owner OFFLINE
  • 2,347 Thanks
  • 1,502 posts
Posted October 05, 2015 - 02:45 PM
Its proper name is a "MODEL No. 135 FIELD MOWER FOR No. 40 TRACTOR" by Waterloo Manufacturing Company Ltd.  The knives, etc, are all identical to the ones on my Simplicity walk behind mower and my Allis HB112 mower, but the pitman setup seems to be unique.
  • KennyP, Talntedmrgreen and boyscout862 have said thanks
#4 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted October 05, 2015 - 05:01 PM
Nice sickle! Hope you can figure it out!
#5 New.Canadian.DB.Owner OFFLINE
  • 2,347 Thanks
  • 1,502 posts
Posted October 05, 2015 - 06:31 PM
This is one of those times when I would rather someone just told me the answer.
#6 Alc OFFLINE
  • 7,126 Thanks
  • 7,530 posts
Posted October 06, 2015 - 02:01 PM
Are you looking for the exact part ? I have an old unknown knife bar that was with my grandfathers TriTrac when I got it . Not the small knives like yours but has a ball at the end you might be able to make work . I can post pictures if you would like this evening ,Al
#7 New.Canadian.DB.Owner OFFLINE
  • 2,347 Thanks
  • 1,502 posts
Posted October 06, 2015 - 06:36 PM
I am looking for pictures.  Anything you can show me would be helpful.  That said, if someone has the part, I would be interested in it.
#8 Alc OFFLINE
  • 7,126 Thanks
  • 7,530 posts
Posted October 06, 2015 - 07:11 PM
Here's what I have . Not sure of the size but can get it if you want . it's riveted to the knife bar.
#9 New.Canadian.DB.Owner OFFLINE
  • 2,347 Thanks
  • 1,502 posts
Posted October 06, 2015 - 08:01 PM
That helps.  Gives me a better idea of what I am missing.  Your bar looks like a Dearborn cutter bar, if that helps you any.
http://www.ntractorc...sages/5384.html
http://www.ntractorc...sages/5389.html
#10 Alc OFFLINE
  • 7,126 Thanks
  • 7,530 posts
Posted October 06, 2015 - 08:50 PM
If you can make it work its yours
#11 MH81 OFFLINE
Posted October 07, 2015 - 06:37 AM
Looked last nite thru Dads old sickle stuff.
Nothing like that bracket. There was an old bar around, but it was like Al's. flat bar with a ball
If you build it, make sure it's solid. It is going to have a lot of abuse just running it, let alone using it..
#12 New.Canadian.DB.Owner OFFLINE
  • 2,347 Thanks
  • 1,502 posts
Posted October 10, 2015 - 05:59 PM
So, here is what I came up with.  Look more like the Dearborn than the original, but it should work.  The hard part was figuring out how to make the ball.  Yes, that is a 1/2" round over router bit, for those who are going to ask.
1.jpg 2.jpg 3.jpg 4.jpg 5.jpg 6.jpg 7.jpg 8.jpg 9.jpg 10.jpg 11.jpg 12.jpg 13.jpg 14.jpg
  • olcowhand, DougT, MH81 and 3 others have said thanks
#13 MH81 OFFLINE
Posted October 10, 2015 - 06:43 PM
Hey, that dog will hunt!
#14 steve b OFFLINE
steve b
  • 121 Thanks
  • 221 posts
Posted October 10, 2015 - 07:10 PM
I never would have thought about using a router bit to cut steel. Brilliant! How was the carbide when you were done?
#15 New.Canadian.DB.Owner OFFLINE
  • 2,347 Thanks
  • 1,502 posts
Posted October 10, 2015 - 08:28 PM
The bit looked as good as new.
