* * * * * 1 votes
Slew of questions in no specific order
24 replies to this topic
#16 Curtis1480 OFFLINE
Curtis1480
  • 19 Thanks
  • 26 posts
Posted November 06, 2015 - 07:26 PM
Got the new limiting post in the mail today. A bit more rugged than I expected, its made from 3/16" thick stock. A piece of thick 1-1/4" angle would do the trick if u want to make one. I know its tough to get accurate dimensions from a picture so let me know if u need something more than these pics.
#17 TrukTruk OFFLINE
TrukTruk
  • 15 Thanks
  • 29 posts
Posted November 07, 2015 - 12:42 AM
Wowsers thanks for all the great info! No reason for me to not fab one up now.
See any reason for the large hole in the center? I'm assuming these bolt underneath the rock shaft bearing block and don't see what that accommodates.
Edited by TrukTruk, November 07, 2015 - 12:46 AM.
#18 Curtis1480 OFFLINE
Curtis1480
  • 19 Thanks
  • 26 posts
Posted November 07, 2015 - 09:41 AM
it does bolt to the bottom of the rock shaft pillow block. I assumed the large hole was clearance for a grease fitting or something but i havent had a chance to look under my tractor and confirm that. ill check it out this afternoon.
#19 UncleWillie OFFLINE
  • 16,253 Thanks
  • 8,970 posts
Posted November 07, 2015 - 02:59 PM
Answers in no particular order;
No, sorry can't help, no, mmmmmaybe!
I came here to post the same thing.
#20 TrukTruk OFFLINE
TrukTruk
  • 15 Thanks
  • 29 posts
Posted November 07, 2015 - 04:26 PM
Ay far as mine is concered, no such zerk fitting exists.
#21 artbuc OFFLINE
artbuc
  • 107 Thanks
  • 185 posts
Posted November 08, 2015 - 04:02 AM
Are you sure? Maybe it was removed or broke off. You might want to take a closer look.
Edited by artbuc, November 08, 2015 - 04:03 AM.
#22 Curtis1480 OFFLINE
Curtis1480
  • 19 Thanks
  • 26 posts
Posted November 08, 2015 - 07:28 AM
The large hole IS to allow access to a grease fitting. I would take a closer look, Artbuc may be correct that it has been removed or broke off.
#23 Curtis1480 OFFLINE
Curtis1480
  • 19 Thanks
  • 26 posts
Posted November 08, 2015 - 07:40 AM
I will get some pics up of the spring assist as soon as I get the snow blower mounted up to the machine, hopefully that will help with the rest of your setup. Just an FYI you will most definitely need some weight ballast on the rear of you machine to compensate for the 300LB snow blower hanging way off the front. I may have gone overboard but I have my rear tires liquid filled (77lbs of liquid each) and 50LB per side wheel weights plus a custom rear weight bracket with 350LBS of 2"x4"x18" (10 pcs)
 solid steel bar stock stacked in there (pics of that setup to come soon on a new post)
Edited by Curtis1480, November 08, 2015 - 07:41 AM.
  • KennyP and TrukTruk have said thanks
#24 TrukTruk OFFLINE
TrukTruk
  • 15 Thanks
  • 29 posts
Posted November 12, 2015 - 12:59 PM
 Got around to making the Arm and Strap (your print was spot on). No access to a welder so I just used a 1/2" SHCS, jam nut and drilled a hole for the kwik-pin. Drilled all thru holes in the center of the stock for the arm. No binding to be seen. Anyone else who feels like fabbing these up watch your bolt hole location to mount the arm beneath the bearing block as it may interfere with a welded stop on the rock shaft if they are to far to one side.
Edited by TrukTruk, November 12, 2015 - 01:02 PM.
#25 Curtis1480 OFFLINE
Curtis1480
  • 19 Thanks
  • 26 posts
Posted November 13, 2015 - 12:46 PM
looks great!
