Rear Scoop & Box Blade
13 replies to this topic
#1 FixItCharlie OFFLINE
FixItCharlie
  • 574 Thanks
  • 361 posts
Posted October 01, 2015 - 09:36 PM
Some time ago I made a Rear Scoop.
By removing these pins the bucket can be removed some of my original thoughts on this was having the ability to turn the bucket around so that it could be loaded by driving the tractor. I have not tried this yet as I still have some things to think about to make this work.
If you have ever worked on a garage door you may recognize what these pins are. Now to use this frame for a box blade.
This may even be used with the bucket I am still thinking on the future of this devise.
Now to attach the box blade.
The extra holes in the 2 X 2 is for angling the blade.
The box blade it is still in the construction phase so everything is still rough looking.
The box ends of the blade are bolted on.
The mounting of the blade is 1/2 inch pins so that it could pivot to adjust the angle of the blade.
This an attempt to show the blade being angled.
This is the teeth for breaking up the soil. Some testing of these show that they do work but may need some modifications as they are being used more. As of now it seems to be a working tool, now using it to learn what modifications will be needed. At this time the handle for latching the bucket is not mounted on the frame but will be reinstalled & I have some thoughts to changes for it. Making an implement that can be modified for different tasks is the real challenge. The thinking & studying for future needs can be the fun part of building implements like this.
Charlie
  • DH1, Gtractor, Alc and 7 others have said thanks
#2 KennyP ONLINE
  • 40,881 Thanks
  • 47,094 posts
Posted October 02, 2015 - 04:52 AM
I enjoy the build more than using the implement. I guess it's the challenge of making it all work. Good job!
  • backwoods, Bmerf, michael.kitko and 1 other said thanks
#3 Alc OFFLINE
  • 7,226 Thanks
  • 7,578 posts
Posted October 02, 2015 - 05:14 AM
Nice how you made the framework of the first box blade as something you can keep making other attachments for like this scraper :thumbs:
  • FixItCharlie said thank you
#4 shorty ONLINE
shorty
  • 5,833 Thanks
  • 5,414 posts
Posted October 02, 2015 - 05:34 AM
I like that scoop. It is neat how you can split the bucket from the frame.
#5 FixItCharlie OFFLINE
FixItCharlie
  • 574 Thanks
  • 361 posts
Posted October 05, 2015 - 08:21 PM
While using the box blade some this weekend I found some weak points in the mounting. I took the old mount apart  redesigned it. I think this will be a lot stronger & last longer.
While I had it outside where I could get more distance from it I tried to capture having the blade angled. One picture with it angled both ways.
  • KennyP and CanadianHobbyFarmer have said thanks
#6 FixItCharlie OFFLINE
FixItCharlie
  • 574 Thanks
  • 361 posts
Posted April 17, 2016 - 01:40 PM
I made some changes to the dump mechanism for the scoop that should make it better.
I had cut some more slot in the catch for the lever but after the assembly completed I found that a stop is needed.
One of the things I always thought about with this set up was turning the scoop around. I will do some testing of this idea.
I am also studying a way to put hinges so that I have a way to change the level for the box blade.
Charlie
#7 FixItCharlie OFFLINE
FixItCharlie
  • 574 Thanks
  • 361 posts
Posted February 04, 2017 - 11:26 PM
As I mentioned in my last post of hinges on the box blade, I have started working on this. One of the problems I found with the box blade is as the box blade fills being able to control the release of what has been scraped up. Researching & studying the use & adjustment of box blade I found that box blades that are used with a three point hitch are capable of having better adjustability. My box blade uses a sleeve hitch so it does not have the top link to make some of the adjustments so I used hinges so to have more adjustments. The strength of most hinges I did not feel last with type of abuse so I made my own.
Each block is made of 1 1/2 inch long piece of 3/4 X 3/4 square rod. Drilling & using a bolt to make the pivot. Welding these to plates makes the hinge.
Now I cut off the mounting plate to put the hinges on.
Then weld the hinge into place.
Now finding the way to use the handle to make the adjustments that is wanted.
Charlie
  • Alc, KennyP, backwoods and 1 other said thanks
#8 KennyP ONLINE
  • 40,881 Thanks
  • 47,094 posts
Posted February 05, 2017 - 06:00 AM
A sleeve hitch limits what you can do with implements. Sometimes, more bite is needed, sometimes less. I find I adjust the top link a lot with my 3-point BB. Just depends on how much I want to dig up.
#9 FixItCharlie OFFLINE
FixItCharlie
  • 574 Thanks
  • 361 posts
Posted February 05, 2017 - 01:44 PM
Yes Kenny that is true but I am not sure that I want put a 3-point on my tractor at this time. Many other projects to work on but maybe after I retire in a year it may be an option.
Charlie
#10 KennyP ONLINE
  • 40,881 Thanks
  • 47,094 posts
Posted February 06, 2017 - 06:50 AM
Here's a rough sketch of one way to change the angle of attack.
Turn the threaded rod to adjust the blade angle.
#11 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,179 Thanks
  • 697 posts
Posted February 06, 2017 - 09:11 AM
I like your blade and scoop. I am hoping to build a rear blade this year and I may try building a scoop like yours as well. Last year I built a sleeve hitch dump rake, starting with a tow behind dethatcher. It has an angle adjustment very similar to what Kenny has pictured.
Jim
Edited by KennyP, February 06, 2017 - 09:33 AM.
Adjust Gravity
  • KennyP and FixItCharlie have said thanks
#12 KennyP ONLINE
  • 40,881 Thanks
  • 47,094 posts
Posted February 06, 2017 - 09:34 AM
That's what I had in mind. Thanks for the pics!
  • CanadianHobbyFarmer said thank you
#13 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,179 Thanks
  • 697 posts
Posted February 06, 2017 - 10:11 AM
Thanks for fixing the pictures Kenny. I haven't had that issue before.
Jim
#14 FixItCharlie OFFLINE
FixItCharlie
  • 574 Thanks
  • 361 posts
Posted February 06, 2017 - 09:29 PM
I modified your drawing to try to show how I am doing it on mines BB.
I also took some pictures which should help.
You may recognize the handle & catch. They are spares to the lift mechanism on a Ford LGT.
I used angle to reduce the flex as it is being used.
It does pivot the blade up. Connection point will be on both ends of the blade. Now when the box blade is full I should be able to control how much is being released. I may need to change the mounting at the lever end to have more control of the blade pivot. The part that bolted to the angle is to allow some adjustment of the blade also.
Charlie
Edited by FixItCharlie, February 06, 2017 - 09:33 PM.
  • limebuzz, KennyP and Leonard VanCamp have said thanks
