Hydrolic oil capacity for my 300
5 replies to this topic
#1 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted October 01, 2015 - 12:47 PM
SO this weekend im going to change the hydro filter on the 300 i also thought about changing it an wondered what the fluid capacity was an if i had to blead the system? An what the best way to drain it safetly also where is the drain plug??
#2 Trav1s OFFLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted October 01, 2015 - 01:21 PM
IIRC - 5 qts but will check the manual.
To drain, disconnect the line that goes to the bottom of the axle.
  • backwoods said thank you
#3 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,748 Thanks
  • 4,242 posts
Posted October 01, 2015 - 02:42 PM
Hi Greg, here you'll find all capacities
Attached File  John_Deere_CCE_Fluid_Capacities(2007).pdf   81.64KB   40 downloads
  • Trav1s and backwoods have said thanks
#4 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted October 01, 2015 - 03:11 PM
my 300 it built in the 70's
#5 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,748 Thanks
  • 4,242 posts
Posted October 01, 2015 - 03:16 PM
plz have a look at site 33 in the upper third, there you'll find - maybe it helps
#6 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted October 01, 2015 - 08:09 PM
I looked at the filter tonight an got the numbers off it so I'll cross them at work tomorrow an get a new filter an change the fluid out tomorrow night
