Will this tube fit my 22.5x7.50-12 tire?
16 replies to this topic
#1 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted September 30, 2015 - 11:59 PM
Looks like my tube in my tractor finally gave and dumped out all of the water in it. Will this tube fit my tire though?
http://www.tractorsu...em?cm_vc=-10005
#2 KennyP ONLINE
  • 38,242 Thanks
  • 45,869 posts
Posted October 01, 2015 - 04:58 AM
Never heard of that tire size.
  • Firefighter912 said thank you
#3 chieffan ONLINE
  • 10,105 Thanks
  • 6,621 posts
Posted October 01, 2015 - 06:29 AM
Not in modern times anyway.  There were some 7.50-5 and 7.50-16 tires way back when but not a 7.50 -12.   Must be an old tire or off brand.  If that is the correct size tire the tube will probably fold on the inside from being to wide.
#4 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted October 01, 2015 - 07:22 AM
I think its the same sears tire that came on the thing.
#5 TAHOE OFFLINE
TAHOE
  • 7,950 Thanks
  • 5,667 posts
Posted October 01, 2015 - 07:25 AM
Yep, I believe my old suburban has "22.5 x 7.5" stamped on the side.
Website won't open for me so I cannot advise if that tube would work.
#6 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted October 01, 2015 - 07:27 AM
See..mines the same as these
http://pages.ebay.co...9857907&alt=web
#7 KennyP ONLINE
  • 38,242 Thanks
  • 45,869 posts
Posted October 01, 2015 - 07:41 AM
Never even knew those were made! Thanks! I would use the tubes you are looking at.
#8 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted October 01, 2015 - 08:56 AM
So the 8.50 will be OK with the tire being 7.50?
#9 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted October 01, 2015 - 09:07 AM
yup perfectly fine
#10 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted October 01, 2015 - 09:28 AM
OK I just wont air it up a lot but good enough
#11 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted October 01, 2015 - 12:44 PM
all it holds in 6 or 8 psi in first place it will be fine trust me put it to specs
Edited by craftsmanmowerfreak, October 01, 2015 - 12:44 PM.
#12 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,909 posts
Posted October 01, 2015 - 01:28 PM
Any Sears I've had in past always had Their brand of tires on them and were like a 1/2 to 1" off standard brands. Think they made them that way so people would think they HAD to buy their tires to fit right. The regular 23" x 8's or so still fit on rims and under fenders. Think was marketing trick.
  Far as tubes, if you look at many new types they say for many sizes right on them now days. Long as the rim size is close, the width part doesn't make much diff, they get plenty bigger  if mounted in a bigger tire or smaller too, long as they aren't so big they get Folded! Have seen that on big trucks, and a few GT's I've torn down. The folds make a place for rubber to go weak and they tear or break there when trying to take out of the tire during a change.
#13 olcowhand ONLINE
  • 41,055 Thanks
  • 31,392 posts
Posted October 01, 2015 - 01:32 PM
Yes, a new tube will be fine.  They stretch to fit the tire, and are plenty small to fit your tire as well.  Now a used tube, once put into a larger tire for a while will never fit well into a smaller size as they develop somewhat of a memory, but new will be fine.
#14 TAHOE OFFLINE
TAHOE
  • 7,950 Thanks
  • 5,667 posts
Posted October 02, 2015 - 07:01 AM
I though we lost our memory as we got older :(   Oh wait, you are talking about inner tubes :D
  • craftsmanmowerfreak and Firefighter912 have said thanks
#15 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted October 02, 2015 - 07:22 AM
Well this tube couldn't fit over the rim...so I'm SOL.
