weights
12 replies to this topic
#1 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted September 29, 2015 - 07:38 PM
Looking for cheap weight to add to my tractor for winter.... ON the rear for some added weight for traction.  This will be going on my briney hitch,, on a Bolens 1556  ..
  I already have my fat a$$ = 200lb  and 40lb weights on the tires... But last year I just kept spinning my tires in a wet snow.. I'm looking at some rubber tire chains to help... But I noticed the weight of the snowcaster is taking away from the rear traction...
  I went to look at maybe some old weight lifting weights ,,, but they want a dollar a pound..  What could I add ,, pound --for pound to add weight to the back end..    I was thinking on the line of something that would have a center hole and put it through the briney hitch hole...  I thought of just filling a 8  or 10 inch tire with cement,, but not sure if that adds a lot of weight ,, compaired to steel,, or lead...
        Any thoughts ,,or what have others used..??      sodi
  • Coventry Plumber said thank you
#2 propane1 ONLINE
propane1
  • 8,724 Thanks
  • 4,131 posts
Posted September 29, 2015 - 08:09 PM
I use old cast iron water trough and fill it with scrap steel. About 175 to 200 lb I get out of that and hang it on the rear. Then figure out a quick attach method. Washer fluid in the tires too, is what's on one of mine. One in picture has loaded tires. 6x12, weight is about 35 lbs each tire. Noel.
#3 shorty ONLINE
shorty
  • 5,485 Thanks
  • 5,263 posts
Posted September 29, 2015 - 08:51 PM
I use a chunk of concrete. Somewhere around 120 pounds.
#4 1oldbuzz ONLINE
1oldbuzz
  • 564 Thanks
  • 448 posts
Posted September 30, 2015 - 12:40 AM
Watch the CL free ads always someone giving away weight sets
or worst case cheap
Last year I found some nice stack weights from a quality weight system (like in a gym)
200 pounds worth for $40
A 5 gallon bucket filled with street sand (free) would also work and the sand barrels will
be coming out soon
#5 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted September 30, 2015 - 04:09 AM
Do you have the tires filled?
Windshield washer fluid is about 8.34 pounds a gallon, and "Rim-Guard" (beet juice) is around 11 pounds per gallon.
#6 Alc ONLINE
  • 6,885 Thanks
  • 7,461 posts
Posted September 30, 2015 - 05:21 AM
What ever you decide on as far as weights you might want to do what I do on my PK ,I made a concrete weight little bigger then 1'sq for the 3pt , it's heavy enough for concerns of wearing out or damaging the lift linkage for a winter's worth of use . I then got a small length of chain and bolt to go through , raised the lift arms and chain it in place to the frame .
  • sodisr said thank you
#7 coop OFFLINE
coop
  • 24 Thanks
  • 103 posts
Posted September 30, 2015 - 06:25 AM
Doughnuts
  • propane1 and alec have said thanks
#8 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted September 30, 2015 - 09:46 AM
Doughnuts
LOL!
#9 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted September 30, 2015 - 12:37 PM
The weight I want will be going on my Briny hitch...  Haven't thought about the hydraulics,, cause the snocaster and the briny hitch will be working at the same time ( up-down )
#10 OldBuzzard OFFLINE
OldBuzzard
  • 7,026 Thanks
  • 4,792 posts
Posted September 30, 2015 - 01:08 PM
Adding that weight to the sleeve hitch may well overload the hydraulics.
I'd look at Rim Guard in the tires instead.
According to the fill chart on their page, 23x10.50-12 tires will take 6.8 gal. which would be 72.8 lbs/tire.
#11 fonz3482 OFFLINE
fonz3482
  • 1,358 Thanks
  • 787 posts
Posted September 30, 2015 - 02:14 PM
I run rv antifreeze in my tires and the cast wheel wieghts. I have gbc lumberjack atv tires on back and man are they heavy! No slipping except alittle on ice.  I ran 2 winters and never had a need to put chains on.
#12 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted September 30, 2015 - 09:02 PM
This is what I did for a Massey. http://gardentractor...hts#entry554498
#13 BTS ONLINE
BTS
    Make Stuff Up
  • 4,263 Thanks
  • 2,459 posts
Posted September 30, 2015 - 10:32 PM
I filled my Kubota (20hp Scut) rear tires full of RV antifreeze, it worked great, I also added 2 pairs of wheel weights (one pair on inside, other pair on outside).
I also have cast iron weights on my Bolens HT23 and I'm getting ready to fill the tires with RV antifreeze. There isn't anyone around there that does the Rim Guard so I had to make due with what I had. I'm very impressed with the antifreeze and it was super easy to put in!
Edited by BTS, September 30, 2015 - 10:32 PM.
