Can anyone help identify this King Kutter implement?
plow
8 replies to this topic
#1 newbie101 OFFLINE
newbie101
  • 2 posts
Posted September 28, 2015 - 01:33 PM
#2 Talntedmrgreen OFFLINE
  • 3,282 Thanks
  • 2,313 posts
Posted September 28, 2015 - 02:08 PM
Looks like a Sears plow, cultivator and rear blade.....and a pair of side panels off an old king kutter rotary cutter.
  • olcowhand, Gtractor, JD DANNELS and 3 others have said thanks
#3 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted September 28, 2015 - 05:11 PM
I agree I do not think King Kutter ever made anything smaller than Category 1, I have a 6 1/2 ft disc and a 3 point scraper and think they make good stuff.
#4 KC9KAS OFFLINE
KC9KAS
  • 5,445 Thanks
  • 4,712 posts
Posted September 28, 2015 - 06:20 PM
:yeah_that: ​ and :welcometogttalk:
#5 newbie101 OFFLINE
newbie101
  • 2 posts
Posted September 29, 2015 - 11:36 AM
Thanks!  Any idea what yard sale value would be?
#6 markus OFFLINE
markus
  • 14 Thanks
  • 18 posts
Posted September 30, 2015 - 03:38 PM
You have a partial set of Sears Garden Tractor Implements , Cat 0  with a 19'' pin bar and a depth wheel for the cultivator and some of the cultivator points and a nice probably 9 or 10 inch moldboard plow for same . The plow is actually quite nice for a small garden and I actually use one for my garden at the side of my house . It will turn up and over a beautiful 6 to 7 inch furrow . Remove the upper draw bar assembly by removing , I think 3 bolts , and using heavy clamps , attach the plow to a draw bar that has been fitted with a stabilizer attachment ( see Omni Drawbar stabilizer ) . You can offset the plow to your desire , along the drawbar for rowing preferences . This will allow you to use the plow with standard Tractor configurations since the distance between the pins on the Sears implements is only 19 inches . If you are interested in selling these odds and ends I would be willing to make you an offer . Call 1-304-733-0101 ask for Mark .
#7 KennyP ONLINE
  • 40,200 Thanks
  • 46,801 posts
Posted September 30, 2015 - 04:41 PM
I think the Sear 3-point was only 12". Normal Cat 0 is 20". These were way narrower!
#8 TAHOE ONLINE
TAHOE
  • 8,185 Thanks
  • 5,765 posts
Posted October 01, 2015 - 07:33 AM
Yep Kenny, that is correct. I call Sears "sub- Cat 0" . It was due to the narrow rear hitch plate/frame.
Value, plow 50-75, cultivator maybe the same. If that is a Sears rear blade with mount, those go for $150 and up in my area.
#9 markus OFFLINE
markus
  • 14 Thanks
  • 18 posts
Posted October 22, 2015 - 04:53 PM
You are 100% correct , I knew it was narrower than a standard but was guessing on the 19 in. , I went out and measured mine and sure enough 12 inches . I have a front mount Sears blade that I rigged for a JD E series tractor , works fine
Also tagged with one or more of these keywords: plow
