And todays debate is on fueling up and oil changes in our GTs
32 replies to this topic
#31 olcowhand ONLINE
  • 41,216 Thanks
  • 31,437 posts
Posted October 04, 2015 - 08:54 PM
I've been using 15W40 in everything from 150HP V8 tractors, all the way down to 6hp small engines for the last 25 to 30 years.  This has served me well.  Might be "wrong", but it works.  Lots easier too, as I keep only one grade of motor oil.
  • Cvans, backwoods and EricR have said thanks
#32 Cvans ONLINE
  • 6,649 Thanks
  • 6,132 posts
Posted October 04, 2015 - 11:41 PM
Daniel it's interesting you have had good luck with one oil. Last year I thought I would do the same thing. I put Cennex 15-40 in the 850 Ford tractor and for the first time since I've owned it I've had to add oil and it is smoking out of the crankcase breather. I've decided that there will be no more Diesel oil in the gas engines. Maybe Rotella would be different, I don't know.
  • olcowhand said thank you
#33 1oldbuzz OFFLINE
1oldbuzz
  • 565 Thanks
  • 450 posts
Posted October 05, 2015 - 03:17 AM
Couple comments
Zinc is and would be of concern in a High HP or High valve spring pressure engine
and its intended purpose was to help prevent premature cam lobe failure.
Everything built today is Roller cams no need for zinc
also unless you a puller your not going to have high spring pressures
Lead was in fuel to aid in the cooling of the valves and eventually lead to deposits on the exhaust valve thus holding the
valve open and loss of compression
the fix was to have rotators on the exhaust valve to rotate the valve to GRIND off the deposits which lead to recessed and burnt valves
But unleaded fuel was the blame for this and the fix was hardened valve seats
And as far as diesel oils they too have less zinc as they also have been changing up to roller cams
And with gas I spend the extra for real gas and it gets treated with stabil its cheaper in the end
Edited by 1oldbuzz, October 05, 2015 - 03:18 AM.
  • Cvans and backwoods have said thanks
