Bolens 1476 Wisconsin engine rebuild.
35 replies to this topic
#31 vtbolensfan OFFLINE
vtbolensfan
  • 69 Thanks
  • 77 posts
Posted February 18, 2016 - 12:05 PM
Very nice work you have done. It will be a family heirloom with the history behind it congrats on a well done project.
Thank you, I will be removing the engine this summer and restoring the rest of the tractor.
#32 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted February 18, 2016 - 05:27 PM
ok yup. I can get that. What do you want it posted for? Just wondering.
http://gardentractor...al-number-threa
willberj is compiling a registry - see the attached post
I am trying to find out how many of each model was made.
#33 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted February 21, 2016 - 11:31 AM
VT,,,   Nice job there...   Was looking for a pic. of the bottom of the connecting rod..  Did it have an oil slinger on the con.-rod cap..???
   also,,, what was the best way to compress the rings to slide the jug over...????
  • vtbolensfan said thank you
#34 vtbolensfan OFFLINE
vtbolensfan
  • 69 Thanks
  • 77 posts
Posted February 21, 2016 - 12:13 PM
Hi, it does have a slinger on it. I bought a new rod and it came with one. I used a piston ring compressor sleeve. I tried it without it but couldn't get it. The Wisconsin manual says to put the piston on the rod. Then put the cylinder on tje block, them put the rod , with piston down through the cylinder. I tried it the other way first, but did not work. I did it how the book said, i should have read the book in the first place. Even with the sleeve type compressor , it was not that easy
Edited by vtbolensfan, February 21, 2016 - 12:44 PM.
  • LPBolens and sodisr have said thanks
#35 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted February 22, 2016 - 10:22 AM
  When looking at the progress in some of your'e pics. ,,  It looked like you had the rod and piston on the block  with out the sleeve..  That's why I asked..    Thanks...
#36 vtbolensfan OFFLINE
vtbolensfan
  • 69 Thanks
  • 77 posts
Posted February 22, 2016 - 10:47 AM
No you are right. I had to remove the rod, put the cylinder on then put the piston with the rod in. Went much easier.
